2 wheel drive to 4 wheel drive conversion
Hello everyone,
I'm a newbe here, I currently have a 01 f350 xl crewcab 6spd manual 2wd that I ordered brand new back in 2000. I wanted 4wd back then but I could'nt justify the cost of it at the time of ordering. So my question to you all out here in superdutyland is has anyone on this forum attempted a 2wd/4wd conversion? I considered finding a wrecked/burned/rolled, f250-f350 to get the necessary pieces.I understand that the 99 & up 250/350 series has two different 4wd type axels under the front end depending on the year, one is held in by leafsprings & the other is held by bars and coils.I would assume that the leafspring setup is the better way to go. Also, does anyone here know if the transfer case for the automatic bolts to the rear of the manual trans or does it take a seperate transfer case?I know it sounds like a awful lot of work& I just should buy a new truck.But just like in 2000 I can't justify the cost of a new truck along with mortgage besides I really like my truck it's been really good to me.Back in 2000 it was just lack of extra funds to make that inflated payment. So is this possible or is it just a pipe dream considering what used/wrecked f series trucks are worth? thanks in advance!!!
Good questions. I guess the best place to start would be pricing all of the necessary components to convert it. Depending on what you can find in salvage yards, etc., it may be do-able. I've never tried it myself. I just ordered mine as 4WD when I bought it. Having said that though, as far as I know, all 1999 to 2004 F-250 / 350s were leaf sprung in the front end. The coils and radius arms started with the 2005+ models. There are a lot of these trucks and parts in the junkyards around here so I don't think finding the parts will be the problem. The biggest cost is probably going to come in the form of the labor involved. It depends on how much of the work you can do yourself.
To be honest, and others can chime in, you would probably be just as well off to buy a good used 4WD or trade yours for a new one. With the current offers from Ford, you can actually get a pretty good deal. I know what you're saying about the cost and mortgage, etc. It's a big pill to swallow. If you convert yours, you may spend a lot of time afterwards trouble-shooting problems as they creep up.
I'm guessing that you'd be better off to find a complete undamaged 4WD chassis and just swap your body, etc. on to it. By the time you get all of the necessary components (front axle, transfer case, rear spacer blocks, springs, steering gear, etc.) and then pay someone to install it and convert yours, you'll probably come out better financially.
Just my $.02 worth. Also, if you decide to convert your current truck, take some good photos along the way to post here for others considering the same.
Good luck with whatever you decide!
Just my $0.02....
but it makes sense...if you had the time AND you could find a scrap truck with ALL the parts in good condition...AND had the available down-time on the truck...AND you were fairly mechanically inclined....You could do it in the winter. Been thinkin bout takin on the same project myself with my '03 F350. Bought when I lived in Cali....who needs a 4x4 in Cali??? Well up and moved to Michigan....snow really sucks...with weight and cnow tires....still have issues gettin in and out the house with all the steep hills around.
If I decide to take it on...I will be sure to post pics and progress updates..
Just my $0.02....
As far as the conversion it would be an in adventure, selling and getting a 4WD is really the easy way out and there is an abundance of used trucks out there to pick from.
I live just outside of Detroit, must have had at least 10 inches of snow yesterday. My 2wd with the Michelin tires doesn't miss a beat, but I know if your out in the country that those roads and hills can be scary in a 2wd. There is no easy cure other than good tires and some weight until you decide to change it over or buy a 4wd. You never know after a couple of our winters you might become an expert and not need the 4wd.
Are all 2wd SD trucks coil spring front ends?
If they are, doesn't it make the most sense getting a 2005 and newer 4wd system that was set up for coil springs? If the springs mount in the same place this would save a ton of work. I guess all the bolt holes on the frames will be there for the conversion if you go to leaf spring anyway. The big advatage you might get is a lower mileage doner truck and tighter turning radius of the coil spring front end.
Good luck
Good luck
The coil front on the 05+ years is completely different. All the frame attachments for 2wd come off the frame and new ones bolt on. You will need the leaf spring type for a 2001 frame. Transfer case is tranny specific, also manual shifter or ESOF, I would go manual, it is simpler to have the shift lever? you also have to change tranny mounts and cross beams, drive shafts, new axle, is specific for 250 or 350, the 350 has more splines in the axle shafts. So, ideally, you need a 1999 late model (with same motor options you have for correct spring rates) up to 2004, manual transfer case, manual 6 sp tranny, in an F350 for a donor vehicle. For the ideal donor, I would think vehicle auction or parts yard. Dont forget, you front axle must have the same ratio, as your rear, whats yours, a 3.73? What engine do you have, this will tell you what front spring codes you want, depending on engine weight GVWR package of your truck.
So, a trade on a local lot or a private sale of yours and a new vehicle seems more logical.
You got that right Redford, change out the body and get on with life. Start checking out ebay and craigslist for a rollover. Here's a good search engine for craiglist, checks all the states listings for what your searching for.
site mash : : combined classified and auction listings
I use it for my cars all the time, pulls from craigslist and ebay.
I've heard that there's only two seasons in Michigan - Winter and road construction.
