Transmission upgrade
I haven't heard of anybody pulling this off. It would require MASSIVE changes to your PCM. The 5R100 transmission is completely different the the 4R100. It'd be a LOT better going with either a BTS or a John Wood tranny, either of those are far better then the 5R100 anyways
One thing nobody mentioned is if the bell housing on a 5R110 is the same?? I'm not sure if it is or not.
As for the controlling of the the 06 tranny if it did bolt up, you could use the same controller Jeremy (jtharvey) used when he destroked his ford.
I believe it's called a PCS - powertrain contol system. Or something similar to that. They run under $1000 I think, and everything I've heard about them is they are awesome!
If the bellhousing bolts up to the 7.3, then it could be done.
BTW - As others have said though, a John Woods or BTS trans would be a custom built alternative for your truck. They'll be in the $4000 range and more if you have it shipped.
To which part??
Here's the link to Bean's website about the PCS:
Beans Diesel Performance - Programmable Electronic Automatic Transmission Controller by PCS (Powered by CubeCart)
When doing a cummins conversion backed by a ford trans or even with an Allison tranny, these are used to control the tranny.
That's why I say, if the 5R110 would bolt up to the 7.3, then I'm pretty sure it could work. Use this PCS to control the trans instead of the factory PCM.
I asked the same question awhile ago, thinking yeah a 5 speed auto T/S would be nice.
I have known a few guys personally that have had these T/S trannies blow on them, and I would take a second to check that out before considering one.
I wonder if destroked wouldnt make an adapter for an allison tranny to go in there.
