Diesel alternative fuels
Old 11-26-2008, 10:05 PM
spuck77's Avatar
spuck77
spuck77 is offline
I know that recently the fuel prices have come down a little, but I am still looking for fuel options. I have looked into bio diesel and veggie oil and am still working on getting set up to make my own. I have recently been looking at adding or building a natural gas injection system. I have heard the same things with this as with all other mods like, it is cheaper to run, gets better mileage, and you've heard the rest. Has anyone tried this or know where to start?
Old 11-27-2008, 06:41 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
Have not tried it but if you are looking for somewhere to start you should scroll down to the diesel section and look at the page devoted to alternative diesel fuels. Further on down and you will come to the Alternative Fuels page. Happy reading.
Old 12-01-2008, 01:13 PM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
All the transit buses in Los Angeles have been converted from Diesel to natural gas, so it can be done. They have the fuel tanks located on the roof, because CH4 takes up much more volume than fuel oil per BTU of heat energy. I think they are LNG, not CNG, something the average motorist would have no source of supply.
Why did you make the statement "gets better mileage"? Its just the opposite, a big hit in range if you dont have room for a lot of extra tanks. A CNG Crown Victoria has about half the range and half the trunk space of a gasoline-powered one.
Jim
Old 12-02-2008, 03:07 AM
aurgathor's Avatar
aurgathor
aurgathor is offline
If they are using methane (CH4), then LNG is highly unlikely.
Old 12-02-2008, 03:44 PM
jimandmandy
Natural gas is methane, in compressed (CNG) or liquid (LNG) form its still CH4. I was not talking about LPG (Butane and/or Propane).
Jim
Old 12-03-2008, 12:59 AM
aurgathor's Avatar
aurgathor
LNG is mostly used during transportation. In any case, I searched, and they appear to use CNG and HCNG. Green Car Congress: City Engines In 30% HCNG Transit Bus Project
Old 05-26-2011, 08:24 PM
pappy2's Avatar
pappy2
pappy2 is offline
alternative fuel systems
spunk77, the cheapest fuel you can make is used oils and diesel blend,you can generaly get used oils from small repair shops, they have to pay companys to pick up used oils, so most of them would gladly give it to you. you just have to be able to have containers and able to transport it to your location. NOTE: be sure to ask if they have added any used coolant to the oils, if they have don't use it. build you a simple filtering system for the oils,use a 50/50 oil to diesel blend or a 40/60 blend oil to diesel,you can add atf if its not already in the used oils helps to burn hotter. this is the blend i have been using in my f250, runs fine, haven't had any problems. do some research on the web if you have dought. just keep your system simple you won't spend a lot of money.
( have a good place to work) use dawn soap to clean up any mess you may make,good luck.
Old 05-26-2011, 08:31 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Responding to a 3 year old thread?..................
Old 05-29-2011, 01:32 PM
pappy2's Avatar
pappy2
pappy2 is offline
if any of you folks are interested in propane fuel for your trucks, a lot of propane dealers can install a unit so you can run on propane, i owned a ford pick up that would run on gasoline or propane, simply hit the switch change from one to the other. ( consider propane is pretty costly + the kit and installing it + tanks needed etc.) but it works. don't know about putting it in a car? or if putting tanks in the trunk is a good idea? any way you can check it out.
fordgal212
1999 to 2016 Super Duty
32
02-23-2021 08:45 PM
Dr. Johnson
09-13-2013 05:32 PM
1999 F350 dually
09-29-2012 05:41 PM
PAVEMENTMAN
06-24-2010 01:05 AM
funzjb1
Bio-diesel, Propane & Alternative Diesel Engine Fuels
09-27-2005 10:01 PM
Quick Reply: Diesel alternative fuels
