Rough idle-'94 F-150 4.9L
Hi guys. My engine has been idling a little rough lately. Plugs, wires cap, rotor, fuel/air filter are less than a year old. I typically stay on top of the routine stuff. The truck accelerates great. I know the timing is good because I had to set it after replacing the pickup coil in the distributor. I ran some fuel injection cleaner through it, but it didn't seem to make a difference. This has been going on for more than a few tanks of gas. It is the same on both tanks.
I got to looking at the IAC. I need to measure the reistance on it as per the manual. I unplugged it while the engine was running and it did get worse. The idle started doing more of a rythmic surging up then down, then up then down. With it plugged in, it stablizes but is a little rough.
When I say rough, looking at the engine it seems to be perfectly smooth. The engine isn't bouncing. But, I can feel it sitting in the driver's seat.
Ideas anyone?
Ideas anyone?
Your seat has Mexican Jumping Beans in the cushion.
Serious note, can you feel it in the steering wheel / breaks / accelerator?
Well, I removed the TB and cleaned it. Looks like the TB gasket might have failed. It is amazing how dirty a TB can get when only air goes through it. Also, the two vacuum lines that connect to the TB were comparable to old marshmellows. I replaced them as well.
Problem is resolved. It idles smooth now.
Thanks for all the help!!!
Nothing Special
33
03-26-2022 03:16 PM
86f1504.9rookie
23
10-05-2016 01:11 PM
96F150-4.9
07-25-2016 07:32 PM
91dirtydiesel
11-20-2011 09:22 PM
