Tire Psi Light
You need the tool on the right; New compact TPMS tool from Ford - Corral Forums
If anybody wants to know, the warranty covers the sensor as a whole, not as pieces. There is a unique way to remove the tire from the rim. If you don't know this you will destroy the sensor and will not be covered under warranty.
and the spare tire does not have the sensor in the tire ether.
sensors
I was surfing the truck accessories sites a while back and saw and ad for tire sensors that did not require a band. It was all apparently inner part of the stem. Wondered if it causes any balancing problems and lots of offsetting weights. Dont know if it was for fords or not, guess I better try to find it again.
the tpms Ford is using is crap compared to the rental cars I have used (Honda Civic and Chevy Cobalt). On those two cars you can toggle through all the different monitors (temp, oil life, etc) and it shows the psi for each individual tire. On my 08 Expy, unless I am missing something, I cant find it anywhere. Of course when I got a Tire pressure monitor error, I had to call the dealer and they asked if the tire pressure is ok, then they said it just needed to be reset. My first question is, what caused the error? unknown. I think they could have come up with a better system.
mebe2k
6.7L Power Stroke Diesel
33
11-15-2015 10:56 AM
BrookPE
03-16-2012 05:06 PM
Alligator06
08-18-2011 09:22 PM
