Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
lightning svt
Old 11-07-2008, 07:36 PM
bdinc94's Avatar
bdinc94
bdinc94 is offline
lightning svt
hey I've got an 01 lightning with a little noise on early start-up...wondering about proper oil currently using 5-30 synthetic and I'm afraid it's not lubing well enough for early morning start-up...plus engine seems to take off a little more than what I'm used to hearing.. any suggestions greatly appreciated... also the truck is located in n. ga. area will be partially garaged [carport] for winter but could be warehoused. thx, bdinc94
Old 11-07-2008, 09:09 PM
3broncocrazy's Avatar
3broncocrazy
3broncocrazy is offline
I've heard that a cheap oil filter would cause that. Not saying that is what you are using, just a thought.......
Old 11-07-2008, 10:14 PM
bdinc94's Avatar
bdinc94
bdinc94 is offline
appreciate the reply..however I've been using fram filters on truck..wonder if I should change to 10w-40 syn-mix for better overnite stick?
Old 11-08-2008, 06:00 AM
ryans428's Avatar
ryans428
ryans428 is offline
Hey there I work for a Ford dealer and unfortunatley the quality of Fram filters has gone down in the past few years. I have found that on several occassions that a slight rattle on start up can be cured by using a Motorcraft oil filter due to it having the right check valve built into it. I think that the K&N and some of the other high quality filters have the right valve as well. I would try that first. You can get a Motorcraft oil filter at Wal-Mart for under 4 bucks it takes a FL-820-S filter. Hope this helps.
Old 11-08-2008, 09:35 AM
bdinc94's Avatar
bdinc94
bdinc94 is offline
Thanx for the info...would rather use all ford on the truck, sounds like now I've got a good reason... thx, bdinc94
Old 11-08-2008, 07:46 PM
tin-man's Avatar
tin-man
tin-man is offline
Welcome to FTE, I agree with using FORD parts, I also think you should use what FORD recommends for oil too!! Just my 2cents.
Old 11-09-2008, 12:30 AM
old87's Avatar
old87
old87 is offline
Evilbeast doc comments-
that motor is a 5.4, and that motor is known for a valve rattle on fire up as well as the blower on that motor also makes a slight noise until the gears and rotors warm up. no matter what oil you are using the motor is always going to have a dry start unless you have a way of priming the motor first. the comments on oil filters is true. but for the most part no one brand is better than another nowadays. on another note, how many miles are on it, what is your oil change interval, and how long do you hear this noise? all of these are things that you need to look at. how hard is it driven, and is it driven for less than 10 miles and on top of that does it get to operating temp when the noise stops? big hp motors like that one dont cope well with being driven short distances and not getting to temp. this is also the case with diesel engines that have to have the turbos heat up before driving, and cool down to prevent oil from coking in the impeller housing. same prospect applies here, that motor needs to warm up before driving and also cool down when parked. i generally go with 2 minutes cool down, and how ever long it takes the motor to come to normal temp. any more info you can provide will help in finding a solution to your problems.
have Donnie (3bc) get in touch with me, he knows how, if you ever have any questions or problems.
Old 11-12-2008, 06:41 PM
3broncocrazy
Woo Hoo, I just knew the good doc would be by here to help!!
Old 11-12-2008, 07:07 PM
tin-man's Avatar
tin-man
tin-man is offline
The DOCTOR is in the house!!!!!!!!
Old 11-15-2008, 12:33 AM
old87's Avatar
old87
old87 is offline
heck tin-man, call him up. the worse your mechanical problem is the more info he has on it.
The Doc got some eerie stuff goin on- trigger belated halloween music here.
Old 11-15-2008, 10:42 AM
tin-man's Avatar
tin-man
tin-man is offline
I don't have anything right now, I'm just working on a few annoying leaks, but you could help me find a beautiful little girl like you have to wash my tires.HA! Mine grew up, now she has me washing her tires, enjoy them while you can. Now my little girl(25) has a little boy(4months) and i am going to teach him how to wash tires. It is just a circle.
nybronc
10-04-2010 05:59 PM
GypsyR
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
22
02-23-2005 07:13 AM
kellyjcook
11-03-2004 05:59 PM
Redneckerson
10-30-2002 12:28 PM
f150boy
04-06-2001 01:11 AM
Quick Reply: lightning svt
