What size of tires can I put on without rubbing on a stock 2005 f250 6.0 4x4?? Thinking of going with BFG All Terrains. Will probably do a leveling kit later on.
hey i have 305/70/17s they are summit mudd dawgs and i hate them but there about 34ish i think on the inch side of things and no lift on the truck according to tire calculator they are 33.8
I have a 2005 F250 and have 295/70/17 (34" tires). I measured mine and my friend's trucks (2005 F250/2005 F350). Mine has a gas engine, his a diesel. His sat one inch lower than mine in the front and one inch higher in the rear. The trucks were optioned the same, so it's my contention that the diesel sits one inch lower in the front, so you may be real close with 35" tires.
cornfiled stroker i have put a new pickture on here so you can see the clearance in the tire and body on a stock 2005 f250 6.0l 4x4 with 305/70/17witch is a 34"
