Competition Diesel racing, sleds, dynos, power tuning and max performance.
Rear End Question
Old 10-29-2008, 11:49 PM
DIESELPUSHER05's Avatar
DIESELPUSHER05
DIESELPUSHER05 is offline
Cool Rear End Question
I have a 05 F350, 4DR, Long box. I dont understand whats going on with the rear end. When I go around a corner on dry pavement and punch it, the inside wheel spins, but the outside wheel doesnt. I thought when the one wheel looses traction, the other wheel kicks in to help. Is there something im missing or is it broken, and would it be wise to make it a solid rear axle so both tires spin at the same time, or I have also heard of an OX manuel cable actuated locker, is this a good idea. PS. the computer is frome quebec so I dont know how to get question mark made, stupid thing.
Old 10-30-2008, 10:56 AM
Dustball8504's Avatar
Dustball8504
Dustball8504 is offline
Thats Fords awesome limited slip for ya.... my truck did the same thing until I had gears put in it and had them put more clutches in it. I read somewhere that most trucks come with only 3 clutches in it instead of the 5 they should have. If your truck is under warranty I'd take it in to Ford and complain that your limited slip doesn't work the way it should. Also if they redo it for you make sure they put extra 2 in for you.
Old 11-01-2008, 05:33 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
You're asking a lot of a clutch type, stock limited slip. It is meant for low traction situations, not pitching it sideways on dry pavement.
A locked rear axle via a spool will push you off the road under the right conditions, and over time will break the axles or at the very least wear your tires oddly and provide clunk and chirp action for your driving pleasure.
More aggressive limited slip (more clutch plates), lockers like the Detroit Locker, or selective lockers like the ARB are available.
willjpw
06-28-2016 07:58 PM
three.on.the.tree
1997 - 2003 F150
01-13-2016 08:20 PM
WickdL
1999 to 2016 Super Duty
10-01-2015 10:26 PM
X GM GUY
18
04-06-2005 10:14 AM
Redthunder
07-28-2003 02:46 PM
Quick Reply: Rear End Question
