Fly wheel issuse's for 1999 Expedition 4.6
Well I was going to move on and pick up a 04 Expedition but recent circumstances are permitting me from doing so. Anyway I'm going to throw another engine into my 99. I have found plenty of 5.4L engines but the 4.6 has been hard to come by. Now recently i have stumbled upon 2 with low miles (70k) at a killer price cause my buddy works for LKQ. My issues is this the two they have are the 8 bolt fly wheel model, but i don't know if i have a 8 bolt or a 6 bolt can any one help?? People keep saying check the VIN it will tell all but that is not the case with my truck when ever i look for parts.
Check the junkyards ahead of time and see if one of them has an 8-bolt flywheel. When you pull the engine if you have have an 8-bolt you're all set. But if it's only a 6-bolt then run down and buy the 8-bolt flywheel and swap it out. Remember to get 8 new flywheel bolts.
I "think" 6-bolt flywheels were used only in the 2WD models, while 8-bolt ones were used in the 4WD models.
So are u saying the same as the other guy that the flywheels can be swapped??? Cause like i said B4 according to the dealership and the site i could have either even though i have a Windsor motor
I know a place with 2 8- bolt motors for decent prices on with 54k and on with 77k. So your saying they are interchangeable like that?? I can change form a 8 to a six bolt?? When i checked my Vin online it said it could have either or so thats why im wondering if i can check which it is b4 i take motor out cause this is my only transportation right now...
JL
You DO NOT HAVE TO CHANGE THE FLEXPLATE as long as the "new" engine has one on it. The torque converters are all the same mounting pattern for 4R70W truck transmissions,and will all bolt right up to the 6-bolt or the 8-bolt flexplate.
JL
JL
The only differences are some minor intake manifold changes,and a few electronic sensors/devices. Sort it all out and it's a very minor difference that can be handled very easily. Worst part will be yanking the old and dropping in the new.
JL
