Will LT275/70R-18 Cooper Discoverer ATR's fit on my 07 Expy EL LTD?
I am going to replace the factoory Pirelli Scorpion STR 255/70-18 tires that came on my 2007 Expedition EL Limited with probably the Cooper Discoverer ATR's. We live on a farm in Michigan and need the snow and mud traction of an A/T tire more than the couple of MPG's we'd get from a highway tire.
The spec's on the Cooper 275/70-18 is 33" tall and 9" of tread width.....The Pirelli's are about 32" tall.
What do you think? Will they fit? You think I'll be happy with these tires? They have a E load rating. I like that because we do a lot of heavy towing with stock trailers and we usually have all 4 kids and 2 adults when we travel with animals. I know we'll give up some ride smoothness, but I should get a little better tread life.
Chris
Chris
Replacing tires with Cooper ATR's
I am in agreement with you, I also plan on replacing the Pirelli's that came on my 07 Expedition. I have 22,000 miles on the tires and they are better than 3/4 gone. I have talked to quite a few people that have had Cooper Discover ATR's and are very happy with them as far as traction and wear. I think you will b pleased with them. Just my 2 cents worth.......
Chris
I rotate every 5K and this seems to help the tires last longer.
As for the taller tire giving you more MPG, that is up to debate, the extra weight and rolling resistance may negate the fuel savings.
i just got the Hankook Dynapro atm RF10's in size 285/70/17, got discount tire to match an online price at $157 per tire. Great deal
10 ply all terrain tire, all the reviews online say they are better than BF goodrich and Toyo at's
4x4 tire review
http://hankooktireusa.com/product/ti...il.asp?pid=290
shows the results of there testing with third party review. Plus do a search on google, motor trend and a few others tested the tires as well.
4x4 tire review
That is true, mine was ridiculously close without the truxxx kit. But I didnt have any rubbing, but it was a little close for comfort. My tires are a bit under 12" wide, I measured today, but I have a huge offset with my rims, so most of the extra is outside the fender, but 100% no rub on the inside of the front, full steer.
Your expedition looks good. I need to get some new pics up of mine.
Thanks Carbon, As far as the truxxx lift, I would consider extending the rear brake lines when you install it, they end up pretty tight and are almost the limiting component in the suspension loop, I didn't put new ones on mine, I am an instant gratification kinda guy, so I just did it anyway.
