how to remove factory radio in an 08 limited
I want to wire in my Sirius Starmate so it turns off when the accessories go off. I tried to wire it from the fuse box thinking it was just like my Stang...it's not, who knows how the dash comes apart and what wire do I tap in the radio's loom for that, Also will the Ford satellite antenna work with my aftermarket unit.
If anybody has a schematic that would awesome
1. turn your key to the run position but leave motor off
2. shift into 1st gear
3. grab the bottom trim panel beneath the A/C controls and remove
4. grab the bottom of the radio surround trim panel and pull out
5. unbolt the radio and pull straight out
6. unplug the wiring connections when accessible
here is a video of the dash demolition for you
EXPEDITION INSTALL
EXPEDITION INSTALL
EXPEDITION INSTALL
EXPEDITION INSTALL
Thanks so much!! Doing an XM direct adapter this week. That video is awesome.
Ryan Cooper
13
04-04-2017 10:25 AM
Shepard
07-14-2006 07:56 PM
