Glow Plug R&R Tip
My elevation is 7000 ft where I live in AZ......I get tons of snow, and temps of -10* can happen on occasion Good glow plugs are a MUST, thankfully I haven't had to utilize my .09 cents worth of ZD-11's yet lol.....but they are in the toolbox collecting dust until needed!
That's just what I paid, a penny a piece and a penny tax.
on
It does sound a bit quieter. I also saw that the #8 injector is not an LL, but an AB like all the rest. No wonder it was so noisy before I did the CCK. Another thing I noticed was the #1 injector that the dealer replaced under warranty back in June 2002 is a reman, WTF. I didn't know enough back then to demand a new injector. That was about three weeks after buying it used from this same dealer. I took it in three times complaining about it running rough between 1200 and 1500 RPMS before they decided that there was a problem. Cracked injector cub at 46k ruined the injector. Fuel in the coolant is why they thought it was an injector cup. Been running great for the last 52k.
No noticeable SOTP performance difference.
none of the early birds came from the factory with a LL injector in #8 or the foil around the IC pipe... the early bird rattle is the reason the newer trucks got the LL injector and foil around the IC pipe...too many people complained about the loud moter and whistle...go figure..now a days we work hard to get the whistle..and the newer truck guy's try to replace the #8 LL injector...lol nice tip on the GP install...
I definitely need to do those things anyways.......minus the glow plugs lol. Ever since I switched to Rotella Syn oil, my truck doesn't even skip a beat starting up in 0* weather without even being plugged in!
If you go under those valve covers to check torque and put in the retaining clips and don't replace the GPs your sanity will be in question.
When using 15w/40 Rotella Dino if not plugged in for a couple of hours when temps were about 35° or lower my truck were get the romps. After switching to 5w/40 Rotella Syn it never romped again, even on the coldest morning, and not plugged in.
Send me a PM.
Edit: With that lift of yours we will need scaffolding.
The LL (Long Lead - AE Code) was a Ford afterthought when customers complained about injector noise. #8 injector is at the dead end of the fuel rail and didn't get its share of fuel especially since it fired right after #6 which is right next to it. The lack of proper fueling caused it to cackle. The LL lessened the cackle by extending the tip of the injector further into the combustion chamber. This did nothing for the fueling issue but just lessened the noise. Ford was installing the LL upon customer complaints. There was a TSB concerning this issue. Ford then began installing the LL in #8 as stock. Aftermarket fuel return kits open up each dead end fuel rail, thus elimating most if not all the #8 fuel starvation. Since mine is an Early 99 with all AB's it means that the original owner never complained about the injector noise and therefore the #8 was not replaced with an LL. Which is better? Well, AB codes flow approx 130-135 cc and were only in the early 99s. 99.5 and up 7.3s came with an AD code that is 135-140 cc. (Someone correct me if I have this wrong). Of course there are many, many aftermarket choices. Do a search for "injectors" and you will be reading for a week.
Bergerson
23
09-25-2014 01:19 PM
crestfallinman
09-05-2011 12:55 PM
