transmission seal
transmission seal
i have a 1990 f-150 and ive had the truck for a year and a half. it has an automatic 4speed with OD. about a month ago i blew out the transmissin seal wile pulling a trailer. i had it replaced and 2 days ago it blew again. i dont know how i haven't pulled anything since the last time. i went to go to the store and i noticed tranny fluid everywhere. please help
Front seal? E4OD?
If it is you probably have a bad clutch fan clutch causing the tranny to over heat. Probably didn't need a new seal to start with.
It is also possible the tranny is reaching the end of its life if it is in fact overheating but I would try everything within reason to make sure it is kept cool before I threw in the towel on it.
One other thing I'd do is check for any codes it may have regardless of the CEL ever being on. It could still have tranny error codes stored without the light ever coming on.
If not a E4OD post the tranny you have and the seal that leaks on it.....
Oh well then I'd check out the output shaft bearings and yoke to see if the shaft has lots of play or the yoke has groves or a nick or bur or something damaging the seal.
Carefully removing without further damage, and then inspecting the seal may lead you to the problem depending on what you find wrong with it.
The output shaft should hardly have any play in it at all. The seal would be able to make up for a little play but not much.
I'm no tranny expert, far from it, but looking at a service manual for the E4OD, the two wheel drive version it looks like the extension housing can possibly be removed and the output shaft bearing can be replaced with the tranny in place in the truck. I'd check with a tranny shop and see what they say if it has lots of play in that shaft.
If the tranny seams fine in every other way, other then the leaking fluid there it may be worth a reasonable cost to have it repaired. Unless you think you might tackle the job yourself, then looks like its a gasket and a bearing or two to doctor it up.
Myself I'd probably do it myself, that is if a tranny shop verified it could be done that way and depending on how much they'd charge to do it.
The manual I have is not the best and doesn't show it but there must be a carrier bearing in the front area of the extension housing supporting the outboard end of the output shaft. Just forward of the yoke spline area for the drive shaft?
Must be self evident to replace it as it's not shown anywhere in the manual how to do so.
Of course I'm guessing here based on a little common sense and on how things are built. Can't have a shaft with a bearing at just one end?
Yes, I found a exploded view of the extension housing and it shows/lists a bushing just inside the rear seal. 4x2 model, Part# 7A034, shows it available as a separate part. (according to the manual I have)
So if the driveshaft's yoke drifts around loose in the hole when inserted in the tail shaft that bushing is probably worn down.
Based on that checking for output shaft play with the yoke removed is not a correct test, sorry bout that.
I see nothing preventing removal of the extension housing to replace it if needed. Does not look like a difficult repair at all.
However probably best if a press is used when removing the old bushing and installing the new one. A bfh may not be the best way to go about it! lol
steve manley
04-06-2014 08:19 AM
Feepaholic
02-08-2009 07:40 AM
