General Diesel Discussion
Diesel P/U get's 40-50 MPG, (see this)
Old 08-30-2008, 04:33 PM
poppie's Avatar
poppie
poppie is offline
Old 08-30-2008, 05:55 PM
tex25025's Avatar
tex25025
tex25025 is offline
I wonder what my inline 3 yanmar engine could do then. Although I'm not going to hold my breath on it though.
Old 08-30-2008, 07:10 PM
poppie's Avatar
poppie
poppie is offline
---------My guess is it would be to small in CID,dont know which perkin's he had but the other truck had a 4610 ford 3 CYL,it is a 201 CID @ around 65 HP,all Ford tractor diesel's of that vintage had the same bore and stroke from the 201 CID 3CYL-256 CID 4 CYL to the 401 CID 6 CYL in the TW series, 10,20 & 30's the diff being some were turboed and some were turbo/intercooled and all ran at 2300 RPM max,understand that the HP of tractor motor's is low while the torque is off the chart's in relation to auto/Pu truck motor's---------<TABLE cellSpacing=0 cellPadding=4 width="100%" border=1><TBODY><TR vAlign=top><TD align=middle>Torque</TD><TD align=left>A twisting or turning force. Typically measured in pound-feet (lb-ft) or newton-meters (N·m). Note that torque is NOT work, even though it is measured in the same units. The difference is that the force in torque is not in the same direction as the distance (it is perpendicular), so it does not count as work. Notice also that lb-ft is used instead of ft-lb; engineers do this as a convenient way to quickly tell the difference between a torque and work measurement.</TD></TR><TR vAlign=top><TD align=middle>Horsepower</TD><TD align=left>A measurement for power that is commonly used in the U.S., abbreviated as "hp". James Watt invented this unit after observing that a horse could lift at a rate of about 550 foot-pounds per second for about an 8-hour shift.--------I think what this mean's is horsepower smoke's the tire's at the light while Torque pull's the load over the hill,to put is another way the Ford 300 CID inline 6 and the ford 302 V8 were with in 2 CID'S of each other,the 302 V8 was faster off the line BUT the ole 300 inline 6 could lug the load up the hill better ,I know,I had both of them,I dont think what he had in the F150's will pull a big load,but for a go to work and save the fuel type truck 40-50 MPG ant to shabbie!!!!!. </TD></TR></TBODY></TABLE>
Old 08-30-2008, 07:11 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
I get a good laugh about how they bitch about profiteers then ask for $50 to learn all their secrets to stick it to those rich bast ards (bas tards gets censored and bitch doesn't?) in the oil industry
Apparently they aren't so mad about it that they won't give their info away to really stick it to the man. I'd get into the fungibility of oil but this is already probably too political to be out of the paid area of the site which makes this all even more ironic.
I'll say that when you complain about how bad oil companies are for making money then ask for money yourself to stick it to them with some ridiculous scheme you are no better than the people you think you are fighting.
Old 08-30-2008, 09:03 PM
efx4's Avatar
efx4
efx4 is offline
I see something like that, and it makes me proud of the fact that a small and unique idea like that could turn into something big. I just don't know how those tractor engines can handle today's automotive emission standards, or provide enough acceleration to make most people happy. But that was awesome.
Old 08-30-2008, 10:32 PM
poppie's Avatar
poppie
poppie is offline
here's more on the tractor to truck engine swap from the state of Georgia web site, georgia.gov - 'Shade Tree Mechanics' Provide Alternative To High Gas Prices and Poor Fuel Economy
Chris Ko
03-27-2017 06:18 AM
Vijay
Large Truck
02-14-2014 09:41 AM
Nj shade
1999 to 2016 Super Duty
13
05-13-2013 09:43 PM
greenmachinejohn
Michigan Chapter
03-30-2008 10:47 PM
Quick Reply: Diesel P/U get's 40-50 MPG, (see this)
