New Oil Titrates high, best way to process?
Old 08-28-2008, 07:33 PM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
The source of oil that we have titrates @ between 8.5 - 9.5 g/liter. Do you guys have a recommendation on the best way to process oil this acidic? thanks.
Old 08-28-2008, 10:13 PM
empiretc's Avatar
empiretc
empiretc is offline
what kind of lye are you using?
Old 08-29-2008, 12:44 AM
bobrl13's Avatar
bobrl13
bobrl13 is offline
Use 22% methanol by volume ratio instead of 20% and process it like normal, your yield will be about 85%. The only other thing you can try is blend it with a lower titrating oil or add some glycol from a previous batch to bring the titration numbers down.
Old 08-29-2008, 09:52 AM
empiretc's Avatar
empiretc
empiretc is offline
i wouldn't be worried if you are using NaOH. That is where a lot of oil I use titrates.
I use 25% methanol and process for ~ 90 minutes. always passes the 3/27 test.
Old 08-29-2008, 12:12 PM
Rushmore X's Avatar
Rushmore X
We are using KOH. We are also looking @ mixing with less acidic oils, but right now this is the only source that we have. Never thought about adding glycerol from a previous batch, might be something to look at. We were thinking of using 22% methanol also.
It is reassuring that you are using oil that titrates that high also. The other place that we want to get oil from titrates @ 1.7 mg / ml, but he is locked into a contract until April.
thanks,
Trent
Old 08-29-2008, 01:40 PM
empiretc's Avatar
empiretc
empiretc is offline
Trent, with KOH the base is 8. are you saying you need to add 9 grams to the base?
Old 08-31-2008, 08:13 PM
Rushmore X's Avatar
Rushmore X
yes, unless we decide to use the acid-base method. This will be the first large batch for us, so I'm not too excited about trying something new, especially where H2SO4 is involved.
Old 08-31-2008, 11:52 PM
empiretc's Avatar
empiretc
empiretc is offline
17 grams/liter is a lot. have you run another titration to be sure?
Old 09-01-2008, 09:56 AM
Rushmore X's Avatar
Rushmore X
Ran 3. but that's better than the oil that we got from venders in Sturgis, it titrated over 12.
Old 09-01-2008, 10:07 AM
empiretc's Avatar
empiretc
empiretc is offline
are you warming the methanol & oil when you are mixing them together?
Old 09-01-2008, 07:45 PM
Rushmore X's Avatar
Rushmore X
haven't got that far yet. Just doing titration. reactor has been put together temporarilly, but its permanant home isn't ready yet.
Old 09-01-2008, 10:40 PM
empiretc's Avatar
empiretc
empiretc is offline
i meant during titration.
Old 09-02-2008, 08:15 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Trent
just for fun re verify your titration KOH solution, just to be sure nothing has been contaminated.
Old 09-02-2008, 09:05 AM
Rushmore X's Avatar
Rushmore X
I re-ran samples that I had done when I 1st made the solution and familiarizing myself with the process and got the same results, so I think the KOH solution is still good.
Sorry empiretc, the methanol reference made me think you were talking about the actual reaction and not the titration. I have been using Isoprophyl alcohol for titration.
Rushmore X
Bio-diesel, Propane & Alternative Diesel Engine Fuels
16
01-14-2015 10:15 PM
kylebryan
13
05-07-2010 02:07 PM
72f2504x4390
10-21-2009 04:45 PM
Rushmore X
01-30-2009 02:13 PM
Rushmore X
06-08-2008 02:01 PM
Quick Reply: New Oil Titrates high, best way to process?
