2001 F250 5.4L Wont start!
Drove it home last night with no problems. Went to go to work this morning, and all she does is turn over. I checked the Fuel pump fuse, it's o.k. I don't hear any pump noise when I turn the key on, and when I checked the pressure port on the fuel rail, no fuel comes out. Checked power at the fuse block and when I turn the key on, 5.5V for about 5 seconds and then ~ 0.5V after that.
Any thing else I should check before I replace the pump?
thanks
thanks
you should have 12volts, not 5.5. i would double check that. if it is ok then i would check the fuel pump shut off switch. it is under the dash by the pass kick panel. then check power at the pump. if you have power then the fuel pump is bad. if you did have 5volts at the fuel pump fuse then you have a problem in the fuse box.
08F150White
2004 - 2008 F150
07-20-2016 06:59 PM
Estes9294
07-01-2014 03:02 AM
