Are NAPA brake pads any good ?
Old 08-12-2008, 02:55 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
Originally Posted by Dukernc
Hey Mark,
Just did a front brake rebuild on my 90' F150 and installed the premium NAPA SD pads along with the premium grade rotors. The combination works great! It stops on a dime and gives you change!! I also have the SD pads on my 99'. Just be sure that what ever pad you choose to use that you perform the "bedding" break-in process. FYI .. if your not familiar with the process..
BRAKE PAD BEDDING IN PROCEDURE
Good Luck!!
oops sorry..didnt see this post......
Old 08-12-2008, 05:20 PM
big poppa's Avatar
big poppa
big poppa is offline
Don't know about Napa pads but got Duralast (just checked) from Auto-Zone and seem to be holding up pretty good. Great price too. The Ford OEM seem to hold up very good also.
Old 08-12-2008, 06:56 PM
whjco's Avatar
whjco
whjco is offline
I had a set of NAPA ceramic pads and new rotors installed on my E350 several years ago. The pads were downright dangerous and didn't have any adhesion on the rotors! They'd just get hot and smoke but wouldn't even lock the wheels. After two weeks I removed them and installed OEM spec. Carquest pads and the stopping power increased about 800%!
Old 08-12-2008, 06:59 PM
ron's power stroke
Brake Tech - Brake Pad and Rotor Bed-In Procedures very inportant with expansive pads...
or the rotors where never turned or replaced when the pads went on...
Old 08-12-2008, 07:04 PM
whjco's Avatar
whjco
whjco is offline
Sorry to respectfully disagree but the rotors were also brand new and I put the pads through a thorough break-in period before I attempted towing with them. I've done my own brake work successfully for over 40 years and never had this problem before or since. NAPA agreed that the pads were defective and gave me a refund on them. The composite material on the pads was as hard as a rock and had little adhesion properties against the rotors.
Old 08-12-2008, 07:09 PM
ron's power stroke
then its not all pads..what Napa was saying is.. just that set you got was bad,,,,had mine over 50k so far...never a problem and not even half worn...thats good info though..thank you..
Old 08-12-2008, 07:10 PM
tag187's Avatar
tag187
tag187 is offline
This kind of thing happens every once in awhile sometimes things slip by the QC guys (sad it was a set of brakes). That doesn't mean all in all they sell a bad product, just got a bad set that time. I Sure will watch and check our fleet trucks more often after a brake job from now on though.
Old 08-12-2008, 07:35 PM
whjco's Avatar
whjco
whjco is offline
Yeah Ron, but they didn't pay for the labor necessary to replace them nor for the hole in my seat cushion where my butt puckered a hole in it when I ran clean through an intersection at a red light with my loaded 9500# 24' car trailer in tow. I was 15 mph under the speed limit when the light changed and it just plain wouldn't stop! I was standing on the pedal and it wouldn't lock the rotors on the van, or engage the anti-lock, and the smoke was rolling off of the trailer tires since the trailer was doing most of the stopping. Later, I had another hill with a T-stop at the bottom and I even slowed down and geared down before starting down the hill. Even then, I had difficulty stopping and the smoke was rolling off of the van brakes. We were on our way to an antique car tour in NY (we're in Lexington, KY) at the time and I had to drive like I was on eggshells the rest of the trip out and back. After that kind of experience, I'm a little reluctant to try NAPA ceramics again.
Also, the practically brand-new rotors were warped from all the heating and NAPA wouldn't replace them, so I literally got burned on a new set of rotors. Yes, there was enough meat on the brand new rotors to turn them true but I didn't trust them to remain true after having experienced that much heat. AND I buy enough parts from NAPA that I'm on their fleet pricing plan. NAPA refunded the price of the pads but didn't compensate me for the damage to the rotors nor the replacement labor that they caused.
I feel that I've paid well for the right to be disappointed with NAPA's brake pads.
Old 08-12-2008, 09:18 PM
cangim's Avatar
cangim
cangim is offline
Yeah, if I had that happen I would be very reluctant to recommend anything as well. After the initial bed in time did the brakes feel weak? I would think that if it is pushing you that much through and intersection that they had to be very marginal to begin with in stopping power. Hopefully no harm done other than the crap rotors and brakes. I have been pushed through a stop sign before with a trailer. Totally changes your outlook when towing things.
Old 08-13-2008, 12:07 PM
whjco's Avatar
whjco
whjco is offline
I spent about 10 days breaking them in and they felt pretty good when we left on the trip. Most of the mileage was Interstate and I generally try to be pretty gentle on the brakes, particularly when I'm pulling the trailer. It was like they suddenly glazed on the panic stop and lost their adhesion on the rotor.
Old 08-13-2008, 12:41 PM
Dukernc's Avatar
Dukernc
Dukernc is offline
Ok,
From what I have read recently about bedding brakes it is very important that the rotors and pads be properly bedded. However. what is also very important is the proper bedding technique for the type of pads being used. OEM, metallic and or ceramic all have different characteristics and therefore require a different bedding process due to optimum operating temperatures and how the material reacts due to the operating temperature. I've attached another link that I found and at the bottom are two (2) additional links for bedding procedures based on the type of brake material (stock, performance) being used. Hope this helps.
StopTech : Balanced Brake Upgrades
Old 08-13-2008, 09:07 PM
BrokenBit's Avatar
BrokenBit
BrokenBit is offline
What's the concensus on ceramic pads vs. non-ceramic (conventional)? I'm due for rear brakes myself and was calling around for prices today, seems the ceramics are generally more expensive but one place had them on sale for less than the "regular" pads. I don't really know what the diff. is????
  #28
Old 07-25-2016, 08:11 AM
Bostonbilly's Avatar
Bostonbilly
Bostonbilly is offline
Swear By Them
Never an issue better than the Factory. Ones that failed on me twice. Buy with confidence good luck
stan'37
1999 to 2016 Super Duty
11-03-2017 09:49 AM
seagiant
01-24-2017 06:39 AM
Mark_in_co
12-08-2016 09:46 AM
andym
11-18-2016 04:28 PM
BBsound
09-23-2016 07:43 PM
Quick Reply: Are NAPA brake pads any good ?
