Pay load capacity on F250
Old 08-11-2008, 11:41 AM
Pest007's Avatar
Pest007
Pest007 is offline
Looking to pickup a load of flagstone, a pallet weights 3000lbs, can I put in in the back ok, or should I tow the trailer?
Old 08-11-2008, 11:47 AM
plowhand's Avatar
plowhand
plowhand is offline
Playing in the Dirt
Trailer. Truck rated for 3/4 ton (1500 lbs) granted it will carry alot more but if you were in an accident, you would get torn a new one for carring that kind of weight, and some times your insurance company would not pay off due to "owner disregard for vehicle weight rating".
Old 08-11-2008, 11:54 AM
Pest007's Avatar
Pest007
Pest007 is offline
Thats what I thought, but couldn't remember what the payload was...
Thanks
Old 08-11-2008, 06:42 PM
heathrunkles's Avatar
heathrunkles
heathrunkles is offline
I thought the payload was around 3,000#'s Even if its not the truck will handle it no prob. I constantly put in 2 1600# pallets--Just make sure you got a good set of shoes and pads on.
Old 08-11-2008, 08:59 PM
lazerf250's Avatar
lazerf250
lazerf250 is offline
Ya it will hold a lot more then they are rated mine is beefed up but i have had 3 tons of wet gravel in the back a couple times sagged alot but drove just fine.
Old 08-11-2008, 09:08 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
figure the avg 250 has a gvw of 8800 lbs, mine weighs about 7400-7500 lbs. you dont have much extra to play with. it doesnt matter what it WILL do, its all about what it CAN do.
Old 08-12-2008, 02:33 PM
phillips91's Avatar
phillips91
phillips91 is offline
also depends on how much his truck weighs to start with. mine is just a reg cab xl and it weighs 5500 lbs. so i could handle a 3k lb pallet and still be under 8800 lbs. its handled it fine on many occasions. but once you start adding an extended cab, tool boxes, bigger tires, etc, you use up that 8800 lbs a lot faster than you think. so yeah, your truck will handle 3k lbs no problems. but unless you have just a bare bones truck, it wont do it legally. just my opinion, but if youre hauling it 2 miles from lowes to the house, i wouldnt worry about it. but if youre going to be on the road for any length of time i would stay legal. not because the truck wont handle it, but because like the others said, if you have a wreck, whether its your fault or not, insurance wont pay for it if you are overloaded.
i dont know about the obs, but on the 99 to about 04 or 05 superduty, the only difference between the 250 and 350 is the 350 has a 4" block and the 250 has a 2". at the end of the day, they will handle the exact same load with the exact same ease, but the 350 gets that 9900 rating because it has a different sticker on the door.
JimG1098
09-13-2016 01:20 PM
bkvanbek
11-26-2013 06:05 PM
oig2scout
12-06-2009 10:47 PM
MikeB 88
Site Announcements
36
03-28-2009 08:24 PM
bullit340
1999 to 2016 Super Duty
21
11-26-2006 01:19 AM
Quick Reply: Pay load capacity on F250
