ignition module bolt size? 95 f150,fender mounted module
Old 08-11-2008, 11:08 AM
cjben's Avatar
cjben
cjben is offline
I am changing the ignition module on my 95 f150 5.0. It is the fender mounted module,underneath the hood hinge. My truck is tall,no matter what I do,I can't get my head in there to look into the bolt holes to see the size/type of the head the bolts are(even tried my step stool,can't get a good angle to see in there),thought somebody might be able to give me a little info!! thanks,Ben
Old 08-11-2008, 11:52 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
I used a thin wall 5.5mm nut driver out of an old electronicts service kit I have. There is an english equivelent, but I don't know what it is. Whatever you use its got to be thin.
Old 08-11-2008, 12:03 PM
macmillanracing's Avatar
macmillanracing
macmillanracing is offline
the little bolts that hold the module on are 5.5mm. The socket I had almost fit but ended up tapping on the end to get it to sit in there. I removed the whole module & heat sink together, I think it was 3/8" that hold the headsink to the fender but I could be wrong, only ever swapped it once myself.
While you might be able to remove just the module from heat sink, you might want to remove the whole thing in one shot. Probaly easier and if the module was never changed, it'll be easier to clean off the old gel/goo that goes between the two pieces and apply the new stuff.
Hope it helps.
Old 08-11-2008, 01:06 PM
cjben's Avatar
cjben
cjben is offline
well,that figures. it probably is 5.5 mm,because that is the only one I don't have I did take the heat sink out with the module. looks like I get to go socket shopping tomorrow morning after work. The "goo" that is on there if it is original,does that need to be replaced? is it dielectric grease? my new motorcraft part did not come with any goo or dielectric grease. should I buy some to put in between the heat sink and the ignition module?
Old 08-11-2008, 02:07 PM
subford's Avatar
subford
subford is offline
YES
NO but that is what all of the books say to use but I would go to Raido Shack and get the White Thermal Zinc grease.
imy new motorcraft part did not come with any goo or dielectric grease. should I buy some to put in between the heat sink and the ignition module?
YES
Also make sure they did not sell you the wrong module, If it is BLACK it is the right one and if it is GRAY take it back and get the right one.
Old 08-11-2008, 03:22 PM
cjben's Avatar
cjben
cjben is offline
the module is the black one,and looks like my old one,so I am hoping it is the right one
Old 08-11-2008, 03:52 PM
subford's Avatar
subford
subford is offline
That would be the right one.
Can you post back the part number from the paper work?
Old 08-11-2008, 08:19 PM
cjben's Avatar
cjben
cjben is offline
will post the part # in the morning,headed for work now
Old 08-11-2008, 10:52 PM
ford2go's Avatar
ford2go
ford2go is offline
Hope you found your socket. If I have the math right, it's the same as a 7/32
(.2165 vs .2187). Whatever you get, it has to have thin walls. Some places sell special sockets just for TFIs.
Your replacement TFI should have some of the correct goo with it. Otherwise the thermal grease should be good.
Old 08-12-2008, 07:50 AM
cjben's Avatar
cjben
cjben is offline
here are the parts #'s,or the #'s that are on the modules,not sure if they are the actual part #'s The old one i took out of the truck:f1sf-12a297-c1a,and the new one that I am going to put in the truck:5u2j-12a297-da. They are both black,but have different part #'s. will the new one still work in my truck?
Old 08-12-2008, 07:57 AM
subford's Avatar
subford
subford is offline
Yes it will be OK but is there not a part number on the box or on your paper work.
I think the part number is 5U2Z-12A297-D but wanted to make sure.
The numbers you gave above off the part are drawing or engineering numbers.
Old 08-12-2008, 08:09 AM
cjben's Avatar
cjben
cjben is offline
well,here is something I just noticed. the # on the paperwork is the one you listed (5U2Z-12A297-D),and the # on the new module is the one i listed(5u2j-12a297-da). the only other # on the new module is c11hd.
Old 08-12-2008, 08:16 AM
subford's Avatar
subford
subford is offline
Thank you very much and good luck.
On the sockets I just took one to the grinder and made it smaller.
Make sure you use a lot of White Thermal Zinc grease on it.
Old 08-12-2008, 10:48 AM
subford's Avatar
subford
subford is offline
For anybody that would like to know the difference between the black and the gray ignition modules, push-start, CCD, and wrong part list please read the following PDF as it is quite informative.
Read the article titled:
DOMESTICALLY SPEAKING
in
http://www.capitolautomotive.com/pdf/cccnewsletter.pdf
Also see
Gray = http://fordfuelinjection.com/files/r...I_harness1.gif
Black = http://fordfuelinjection.com/files/r...I_harness2.gif
All 4 TFI's together http://fordfuelinjection.com/files/compare_TFIs.gif
Old 08-12-2008, 11:31 AM
cjben's Avatar
cjben
cjben is offline
got it changed out after I went and bought the tool for it,runs fine,thanks for the help.
sixofspades
33
12-25-2023 10:28 PM
GoldCo
18
06-15-2017 03:16 PM
forkliftjoe
02-13-2017 04:22 AM
autox65
07-31-2016 05:27 PM
Motorhead-42
80
07-27-2016 02:30 PM
Quick Reply: ignition module bolt size? 95 f150,fender mounted module
