What's the direction of flow through heater core?
Old 08-05-2008, 10:22 PM
jtharvey's Avatar
jtharvey
jtharvey is offline
From the firewall side, which one is the inlet and which is the outlet back to the water pump, or does it even matter? I can't remember which one is which. My concern is that there might be some sort of check valve in it to prevent backward flow through the heater core and I wouldn't know it until I needed heat. In my haste and disgust when removing the 7.3, I forgot to mark the hoses. Can anyone help?
Old 08-05-2008, 10:31 PM
clux's Avatar
clux
clux is offline
The upper hose on the firewall goes to the water pump,that's got to be the inflow.
Old 08-05-2008, 10:35 PM
SkySkiJason's Avatar
SkySkiJason
SkySkiJason is offline
Received 1,897 Likes on 1,145 Posts
Supply is on the right, return on the left looking from front of truck. No cv's that I'm aware of , and I've 'messed' with my heater hoses quite a bit!
Following your progress, btw. Keep up the good work!
You rock!
Old 08-05-2008, 10:39 PM
SkySkiJason
The hose to waterpump is return. But that ain't gonna help - he does not have an engine in there... , or if he does it has 2 less cylinders!
Old 08-05-2008, 10:55 PM
clux's Avatar
clux
clux is offline
You are correct, that is the return.
Old 08-05-2008, 11:07 PM
jtharvey's Avatar
jtharvey
jtharvey is offline
My hoses are side by side. I was thinking there is some variation in this between trucks.
That's perfect! That will work out well since the supply on the Cummins is further toward the middle. Thank you for the info. Check another item off the list!
1985L8000cat3208
07-17-2016 10:12 PM
ExBeast
07-13-2016 04:24 PM
brobrad
1997 - 2003 F150
01-27-2015 08:17 PM
LARIAT 85
07-16-2013 11:44 AM
eallanboggs
2004 - 2008 F150
12-13-2010 12:26 PM
Quick Reply: What's the direction of flow through heater core?
