My "68" Hauler.........
I'll probably catch some "crap" from this one.... but I'm a big boy and can handle it!
I took a "68" crew cab, added another section to it, welded the back two doors shut on the drivers side. Then I welded the center door shut on the pass side. Now it's my "3" door pickup! Here is where the "crap" will come.......I installed a Caddy Eldorado 473 ci FRONT WHEEL DRIVE section. I just pulled it out from storage, and will be welding the twin axle trailer from my drag boat to the rear. I added Hydraulic rams to the torsion bars on the caddy front so I can change the ride height from the cab with a switch. The rear tandem axel assy will get the same treatment. I built two aluminum "rails" so I can switch from hauling the boat, to hauling cars and trucks. Hope to have it complete this winter. Some day I plan on building an adapter to install one of my 428s in place of the caddy ( if I live that long....) I would have used Ford Power, but Ford never built a bigblock front wheel drive...............
I "hope" to have it in primer and ready for next years boating season. This is the second one I've done. The first was for a customer, just a straight 67. I couldn't believe how easy it was. It was like it was made to go together this way! The best part for me, was watching the reactions of people when I'd smoke the FRONT tires
Somewhere in storage..................It was built before I had a digital camera I do have a video of when we "mated" the caddy front sub frame to the Ford chassis somewhere tho. As I said it was one of the easyest swaps I've ever done, even the Ford inner fender panels fit with 0 cutting! It looks factory built. I don't know where the first one is anymore, the guy sold it to somebody from California.
There's a HUGE amount of room. Wait till you see what I'm doing with the old trans "hump"............Since there's no trans in the way, I'm building a stainless, insulated, "box" in that space for a beer cooler. Cooled with a separate coil from the AC. Most of the interior and final paint will be a few years away, I've got more projects I want to finish first!
Only as time permits. I'm trying to finish my 67 shortbed with 460 right now. Chassis, engine, and interior are done, just need to finish the sheetmetal and paint it. Plus I crashed my drag boat and have to finish the hull work and get the new 428 cj refreshed and put back in. sooo many projects, so little time!
That's exactly what I was thinkin when I saw it. That would be SO much better looking than any Burb or Xcursion on the road too!...if it was made that way.
