Stock Gear Ratios - 93 F150
Did a search, but couldn't find the exact info need.
I have a friend that owns a 1993 F-150 5.0L 302 4x4 and is wanting to swap gears. Of course he's unsure what came in the truck stock. I've seen 2.73, 3.08 and I think 3.55 and 4.10, but not sure if these were all stock or if some were aftermarket.
Can anyone tell me where to locate the rear diff code at and the description of the code. I know for the 04-08 F150s they break out like this:
19 — 3.55 non-limited slip
17 — 3.31 non-limited slip
H9 — 3.55 limited slip
B6 — 3.73 limited slip
Thanks!
Thanks!
21 rear axles are 18 too many
Axle code is on the drivers door post
12-2.73
17-3.31
18-3.08
19-3.55 (seems like most f150's)
25-4.10
68-4.88
There are 21 possible axles but only the second digit is the ratio code. If it has a letter then it's limited slip, but the last digit will still match up with the ratios given here (B9 is limited slip 3.55). The exceptions are codes 72 and 73which are 4.63 and 5.13 respectively.
12-2.73
17-3.31
18-3.08
25-4.10
68-4.88
on
Typically you'll see 3L55 or 3 55 with a blank space where the L would be. The L of course signifies a limited slip, no letter there means open.
The codes from the door pillar should work as well... Ford Axle Code Chart .: Articles
blloyd29
1999 to 2016 Super Duty
03-28-2016 07:11 PM
1992FordF150Custom
19
05-23-2012 08:42 PM
aaroncarn
02-11-2012 08:40 AM
