'09 5.4L Triton HP/Torque numbers...Released
hmm that's a bit of a disappointment dont you think.. they could of done a bit better especially with everyone else pushing ATLEAST 330+ and getting the Same if not BETTER MPG. granted trucks ain't selling like they used to but still..come on
where did you see this? just curious..
That is a bit of a dissapointment considering people can get more gains out of a CAI and tuner out of an 04-08...
E85 is also much higher octane = able to run more timing = more complete burn = more power. works even better w/ forced induction setups...
I call BS. Ethanol "higher" octane rating is not equivilant to gasoline. It will not prevent predetonation. This has been discussed a billion times by now but ethanol only has @ 2/3ds the nrg of gasoline, so how would a fuel with less nrg somehow produce more power? I can't recall the models but in the past when Ford has had two tiers of output ratings the Ethanol figures were the lower...
Owning an FFV and using E85, I can actually feel a slight, very slight (seat of the pants) increase in performance when running E85. Also from what I've read, E85 can produce more power, it's all based on the compression rate of the motor. If a motor was built soley for E85, the compression rate being considerably higher than gasoline, then you'd get more power and better mpgs when running E85 than gasoline. The reason E85 is so bad on mpgs currently is due to the motors needing a lower compression ratio for gasoline, decreasing E85's efficiency.
I see said the blind man.
So the new 5.4L would then have to able be able to variable adjust compresion based on actual belnd of ethanol in the fuel? So then if after a full tank of e85, if I put in 100% gasoline then it would detmine this and lower compresion as I drive? Or would it be all or nothing in that if it detects e85 I'm running higher, then if a retailer is not honest and actual mix is "e78" I don't get the benefit? Just some q that pop up in my head.
Must have been the 3.0L that I had in my '99 Ranger that was also in the Tauras. Never used E85 at the time or looked into it, but can't say for sure if this was true or not.
And you got those #'s From Where exactly has it been from ford????
