1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Tcil Reset??
Old 07-25-2008, 05:02 PM
Dave Tyler's Avatar
Dave Tyler
Dave Tyler is offline
Tcil Reset??
on a trip and traveled today, hot, pulling trailer, 16 foot,light load. Bad traffic. Noticed light flashing. How do reset?? Staying with friends, 350 miles away from home. Will check later. Any help appreciated. Dave
Old 07-25-2008, 07:00 PM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
It might have been flashing because the transmission was too hot. Heat is the arch enemy of the 4R100.
Let everything cool down and see if the light doesn't stop blinking.
Old 07-25-2008, 10:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
The only way to reset it is to fix what's wrong that's making it flash. Overheating is one of about 50 things that could make the light flash.
Old 07-26-2008, 04:14 PM
Dave Tyler's Avatar
Dave Tyler
Hello Guys, Thanks for the response. I did wait awhile, un hooked trailer and was planning taking to auto Zone to read the codes. When I cranked it, there was no light, took to Auto Zone and said no codes?? So I drove today another 350 miles with no problems. Maybe it was heat, I was driving through Dallas on a Friday Afternoon about 3p.m. and that would make anybody hot!! Have 188,000 on 99 F250. Did replace transmission seal a month or so back and then changed fluid again. Seems to be O.K. When trying to get seal replaced everyone wanted to rebuild the transmission. Never have yet and still going. thanks for the responses. Sure good to have Ex Ford transmission guys respond. I really and truly appreciate your time. Wanting to repay the help. Thanks again. Dave
Old 07-26-2008, 10:37 PM
Mark Kovalsky
There is a trans code stored in the computer's memory, unless Autozone cleared it for you. They don't have readers that can read Ford trans codes, but their readers CAN erase the codes.
Old 07-27-2008, 07:39 AM
Dave Tyler's Avatar
Dave Tyler
Hello Mark, At Auto Zone, the codes were not erased. I had the scanner and saw that option but did not do it. So what you are saying the code is stored in the computer? My transmission seems to be O.K. I just do not have the cash to have it rebuilt so keep hoping for the best. I have had it since new, always changed the fluid and filter myself and the torgue converter every time. Have been using Amsoil synthetic. I know on this sight that brings up 40 pages of reading. I also pull a 35 foot 5th wheel even though lately I have not been pulling it. I have changed the water pump from instructions on this site. I am very happy to get the info here. Again appreciate your input and assistance. As mentioned earlier, I had a problem finding someone to change the seal on front of the Trans. When I did find a guy he did a great job, works at a dealer ship, but did this on the side for $125 plus part. Said he checked u joints and so forth? So that is where I am today. Was sure glad to make it home, about 1100 miles in a week. Thanks again, Mark. Dave
Old 07-27-2008, 09:06 AM
Mark Kovalsky
The code will stay in the computer's memory for about a month after the last time the light flashed. It's still there, Autozone can't read it. A Ford dealer can, or a good indepedant shop could, too.
Old 07-27-2008, 05:28 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
If you have a trans over temp code you need to change the fluid ASAP. when the fluid gets to hot it will break down and cause more damage in the long run.
Check your trans cooler, It may be full of bugs, mud and other gunk that is restricting the air flow.
Old 07-27-2008, 07:01 PM
Dave Tyler's Avatar
Dave Tyler
KRDisesel, Thanks for the info also. Will check what you said. The fluid was just changed less than 500 miles and Synthetic but will check the code and see what happens. Thanks again. Dave
Old 07-27-2008, 07:39 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The scanners AZ uses only read generic codes (0001-1000).
Most, but not all, of Ford's tranny fault codes are "manufacturer-specific (1001-1999)". All it takes is a little bit better scanner than the ones that AutoZone makes available to customers.
Steve
DAVE LACLAIR
03-05-2016 08:05 AM
ssmandavid
02-04-2016 08:35 AM
vidaliaman
01-19-2016 11:25 AM
67F100TX
12-28-2015 05:05 PM
00Dave
02-05-2008 10:44 PM
Quick Reply: Tcil Reset??
