2004 F-150 four wheel drive problems
when the IWE goes bad...or the vacuum pump fails
the front hubs fail engaged. so if it was an IWE problem, you would be in 4x4
check your fuses. I'm betting the relay that tells the IWE to break vacuum isn't working. You can also try taking the vacuum lines loose at the IWE themselves. if the hubs engage and 4x4 works, you know it's an electrical issue somewhere...most likely at the t-case
Bruin52
09-26-2016 09:40 AM
02GrayPowerStroke
1997 - 2003 F150
12-04-2015 05:43 PM
