Tranny change out
Old 07-23-2008, 12:04 AM
Ego Flat 48's Avatar
Ego Flat 48
Ego Flat 48 is offline
Tranny change out
I have a question for the experts...I have a four speed tranny behind a 8BA 239CI, '48.truck. I'd like to go to a 3 speed top loader, perhaps, with an overdrive,but keep my existing bell housing cause it goes well with the engine. Would appreciate any ideas on a good tranny that will hook up simply, cause I'm simple, thats most cost effective and one that I won't have any problems with. I will be driving it alot on the street, no racing, but would like to be able to spin the tires alittle. Thanks
Old 07-23-2008, 06:27 AM
petey shoes's Avatar
petey shoes
petey shoes is offline
ego, there are quite a few posts from the past on 48-60 forum. also, try msn flathead forum. v8bob and moefuzz have an extremely detailed document on ALL bellhousings and oil pans. it's about 60 pages and well worth the time to study. these guys spent a lot of time putting this together!! also, visit moe's garage on the net. between the fte and msn forums, you should be able to answer all questions on your project.
Old 07-23-2008, 07:49 AM
Ego Flat 48
Copy that. Thank you so much. Ralph.
Old 07-23-2008, 10:16 AM
55 f350's Avatar
55 f350
55 f350 is offline
heavy four speed ? if it is ya gotta find the heavy 3 from the same time frame as the heavy and light duty trannies have different tranny to bellhousing mounting patterns . i am in the process { not quite the same as mine is a 53, but give you an idea .} of switching from a light buty t-85 to a heavy t-98 four speed . lots of lil things besides diff bellhousings , to make the switch on mine . had to go from a one peice drive shaft to a two peice , bigger clutch linkage bracket that mounts on the tranny , went from a slip yoke { 3 speed } to the saddle the big trucks use on the output on the trannies .. just some of the lil' nitpicking things that are at present slowing me down and driving me crazy .... oh and did i mention the cross shaft / ujoint i gotta go find . one side a bigger size the other a smaller size ........ give me a lil' bit and i'll be back to edit / add more !!!!!!!!!!!!
Old 07-23-2008, 03:06 PM
soule46's Avatar
soule46
soule46 is offline
Shouldn't a '42-'50 truck light duty 3 spd just bolt in, the 1/2 bell on the engine should match and the clutch setup should be the same. I know some of the larger trucks had a different cross member under the trans, but assuming you have a 1/2 ton based on your F150 designation. You will need a different drive shaft since the light duty has a splined output and the 4spd has the saddle output. That will not give you the overdrive though and from what I have seen has pretty weak gears (I have yet to find one with good gears)
There are a lot of people swapping in the 80s S10 T5 transmission, search here for that swap. Your setup should take the after market parts to do this swap also. It is also possible that the trans side of the 1/2 bell on your setup will unbolt and can be used as an adapter for swapping in a newer style transmission.
Old 07-23-2008, 11:26 PM
Ego Flat 48
Thanks for the input guys. I appreciate your time and effort. I'm glad to get questions answered.
Farmstore34
16
06-21-2013 12:31 AM
48' fordster
04-11-2007 01:38 PM
48fordf1
04-17-2005 07:56 AM
reamer
15
01-22-2005 08:35 PM
Quick Reply: Tranny change out
