Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Easy ways to to get horse power gains
Old 07-22-2008, 02:41 PM
tpaws2008's Avatar
tpaws2008
tpaws2008 is offline
Question Easy ways to to get horse power gains
I have a 2003 HD supercharged i put a new cold air intake (C&L)in, inlet pipe(C&L) , throttle body(big oval) , and upper intake (C&L)in with a diablo preditor tuner. i would like to put a lightening pulley and belt in to give me the extra 40hp and 25torque because i was told that was the only engine power difference between the trucks. im looking for any suggestions for power upgrades nothing like nos but things like exhausts, fuel injectors, etc. also if anyone knows of any good shops around st. louis that would be helpful.
Old 07-26-2008, 09:09 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Skip fuel injectors, you only need them if the truck has a ton of boost requiring more fuel flow than the stock injectors can provide.
The first question I have before going further is: what is your budget?
Old 07-27-2008, 01:21 AM
tpaws2008's Avatar
tpaws2008
Budget im unsure on but not looking to exceed $2000 as of right now i just bought a new pulley which is next to go on i do need to replace the spark plugs and carrier barring.
Old 07-27-2008, 02:30 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
ROTFLMAO! Ignore Ken, he's such a comedian!
We all know we're NEVER stop modifying our trucks, so no budget can contain the continual modding brought about by that pesky bug!
Originally Posted by tpaws2008
...i do need to replace the spark plugs and carrier barring.
Drop the carrier bearing...go with a one piece driveshaft!
Stewart
Old 08-08-2008, 09:06 PM
pkracing03's Avatar
pkracing03
pkracing03 is offline
i would look at rpmoutlet or lightning force performance. you can get a package deal for a good price and most of the stuff you can do yourself. what size pulley do you have?
Old 08-08-2008, 09:26 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Do a web search on rpmoutlet and problems first, also one on rpmoutlet and the better business bureau before you make any purchasing decisions...
Old 08-08-2008, 10:08 PM
pkracing03's Avatar
pkracing03
ya i heard about that on rpmoutlet but i have order some stuff threw them and i didnt have any problems
Old 08-08-2008, 11:38 PM
Stewart_H's Avatar
Stewart_H
Yep, there are a few of you kind of people around. But like a solar eclipse, they are rare.
RPM outlet has way, way, WAY too many complaints about their business practice, their ripping people off practice, their unethical behavoir practice, to even consider telling someone to check them out.
Heck, LightningRodder forum has an announcment at the top of the Gen 2 forum page WARNING people not to do business with RPM Outlet. Mainly for the newbs who don't know better, but it's still a big warning none-the-less.
SVT Performance made a public posting that RPM Outlet was being dropped as a Supporting Vendor because of their BS way of doing business and ripping people off.
DO NOT USE RPM OUTLET!
Stewart
Old 08-09-2008, 05:18 AM
ckirwan514's Avatar
ckirwan514
ckirwan514 is offline
if you live in st louis find stegmeier they do porting and polishing of the intake sys and your superchager they also dyno tune lightings which is the best way to tune your truck. buying a ready made tune is not the way to go. you need a sct hand held tuner most of the dyno speed shops use theur soft ware.
Old 08-09-2008, 12:52 PM
ckirwan514's Avatar
ckirwan514
i should also mention that i still have a diablo sport but i am getting a sct xl as i am moving to the portland area an d it is easer to find a dyno tuner with sct soft ware.as far as hp goes i have 422 hp at the rear wheels done with all bolt mods and a dyno tuner.
Old 08-09-2008, 01:22 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
What bolt on mods have you done to get 422HP at the wheels?
Old 08-22-2008, 10:29 PM
commandersander's Avatar
commandersander
commandersander is offline
HHO! I'm doin mine now FER SURE!!!
Old 08-23-2008, 08:38 AM
ckirwan514's Avatar
ckirwan514
installed the following onmy lighting.
1. air raide cold intake.
2. changed mass air sensor
3. c&l plunim
4. accufB throttle body.
5. matco idler kit
6. matco 6# lower pulley.
7. entire intake sys sent to stegmier in st louis for porting and polishing,including the sc.
8. bassani cat back exaust sys w/two cqts only.
9 t 6 cold plugs.
10. transmiison valve body from chickenears.com
11. dyno tuned at a ford speed shop with a in floor dyno using a act excal 2 hand held and act software on the computer they use which includes fuel/air readings.
all of this is bolt on end result my 02 lighting has 422hp at the rear wheels.
Old 08-23-2008, 03:15 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Which speed shop?
Old 08-24-2008, 08:02 AM
ckirwan514's Avatar
ckirwan514
atlanta chassis and dyno in conyers georgia
Quick Reply: Easy ways to to get horse power gains
