Pilot Bearing Removal??
Old 07-10-2008, 12:30 PM
Truxx1956's Avatar
Truxx1956
Truxx1956 is offline
Question Pilot Bearing Removal??
Hey guys, I am changing my truck ('89 F150, 300 Cyl) from a M5OD to an automatic. I know I need to remove the pilot bearing from the crankshaft, and have been told to find a shaft that will fit snugly into the pilot bearing and pack it with greas then tap it with a hammer. Is this the right way to remove it? Or do you guys have another trick?
Thanks!
Old 07-10-2008, 12:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,571 Likes on 1,049 Posts
Yes, that will work. Wet toilet paper stuffed in the hole works too, and doesn't make as much of a mess.
Old 07-10-2008, 04:04 PM
Truxx1956's Avatar
Truxx1956
Question
Thanks man! Now I got another question for ya after I see you are a trans guru. I have a '79 model C6 and a '90 model C6, I also have a '93 AOD from a cougar. I think I want to go with a C6, between all my choices. My question for you is: Is there a difference between a '79 C6 and a '90 C6? And if I do go with the AOD, is the bolt pattern of the flywheel the same as the C6? I already have a flywheel for the C6 is why I ask.
Also if I do go with the AOD, I know I'm supposed to use a trans PSI gauge to properly adjust the TV cable, can you explain how to do that?
Thanks for all your help!!
Old 07-10-2008, 08:20 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
I use a bearing puller unless the pilot bearing is junk, in that case I use an air chisel. You can rent a puller from Advance Auto.
Old 07-10-2008, 09:13 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,585 Likes on 1,292 Posts
--Pilot removal: On my '65 Mustang, I used a bolt just a little larger than the opening, and threaded it into the bronze. Once a couple threads are engaged, you can lever the bushing out. The grease/tp push out has been reported to work well here also.
--C6 vs. AOD: A '93 AOD is a good candidate, as many AOD issues had been fixed. Was this a V8? Even better. You are going to miss the OD with $5 gas...
--TV cable:
TCI AOD Throttle Valve Adjustment Instructions
Look around the TCI site for lots of AOD propaganda, parts etc, shifters, etc.
Good luck.
FWIW I'd keep the 5 gear, but then you can choose to shift for yourself on that decision....
Old 07-11-2008, 08:23 AM
Mark Kovalsky
Yes, there are many differences. I don't know all of them.
I don't know, but I do know Ford doesn't like to keep the same bolt pattern on different applications.
See the post above this one.
jydrill
1999 to 2016 Super Duty
12-10-2015 12:59 PM
swade-o
11-17-2015 11:24 AM
pat420swed
1978 - 1996 Big Bronco
08-07-2015 07:21 PM
huntingnt
03-16-2007 05:32 PM
tdlover
03-24-2006 06:25 PM
Quick Reply: Pilot Bearing Removal??
