blower motor resistor
I know this has been covered about a thousand times before but I can't seem to understand where the resistor is. My blower only works on the high position and I've read where it's the blower motor resistor but I can't seem to find the resistor. I'm slow so type slow so I understand! :P
Thanks guys.........
T h e b l o w e r motor resistor is located under the hood on some vehichles and inside the passenger compartment on other vehicles. No matter which location it is it will always be in the air flow of the blower itself (the blower will blow air over it). It will have four wires on it and if I remember correctly is mounted with two screws.
It's inboard & below the motor, near the accumulator. You can see it standing beside the passenger fender. You can almost see it in pic #41 ('93 5.8L right.JPG) in this album, but it's the off-white connector behind the L heater hose above the vacuum reservoir & the white WARNING sticker:
http://www.webphotos.com/list_photos.asp?mi=3&smi=1&a=66912
I don't work for Webster. I have been repairing, installing, and troubleshooting electric and electronic circuits for about 30 years. The blower motor resistor is NOT a rHeostat. A rHeostat is a variable resistor. The blower motor resistor has fixed taps on it that give stepped blower control. The resistor itself is not the controlling device. The controlling device is the **** on the dash.
Your not at all **** either are ya. If I told you I needed a "reostat" for my car would I get 30min lecture on resistor component theory?
Don't correct my engish, spelling or terminolgy. If I'm talkin to you, and you don't understand me, feel free to ask. If you want to teach electronics, do it in a classroom. With you guys around, who needs heat.
A) If you told him you needed a "reostat", he'd probably give you a "rheostat" for the dash light dimmer inside the headlight switch since he knows what a rheostat is.
B) If you were in a technical forum and used the wrong term, yes, you would be corrected. If you want to spread disinformation without being corrected, start your own website called "Mye_oppinyuns_abut_ evverting.com" and say whatever you want using whatever spelling you think is right. This BBS is here to help people by giving them correct information, including terminology, and the language most often used here seems to be English, whose words already have spellings so there's no need to add confusion by creating your own spelling for words that already exist. Wenn du Deutsch schreiben moechtest, koennten wir uns auch unterhalten, aber bitte, keine Vertippungen.
C) It appears he DID understand you, but the next person to read this thread might not if you use the wrong terms, spell them wrong, or use another language.
D) This forum IS a good place to teach electronics as they relate to Ford 12V HVAC. That's why it exists.
E) It takes 2 to tango, and you're continuing to use terms you know are wrong just as much as he is (& I am) continuing to correct you, so you're generating just as much "heat" as we are.
