Wiper Delay Module
Wiper Delay Module
I didnt' even know my 85 F-150 was even supposed to have intermittent wipers until someone told me I had a wiper delay module. I replaced the wiper switch and the intermittent part just goes at the same pace as the slow setting. Does this mean that the module is bad? And if so, where on earth can I get a new one.
on
One click to the right, from off, slow speed. Two clicks to the right Fast.
Turn the **** to the left, all the way to the left is about 15 to 20 second pauses. All the way to the right of the intermittent section of the switch is 1/8 of a second pauses. Almost but not quite as fast as slow speed.
Wrecking yards are your best bet for a module, and switch.
1980-1991 F-series pickups.
1980-1998 F-series mid size trucks F-600 Up.
The post about your cruise conrol amplifier said it sounded like you were describing a wiper control box. Its possible you could have been describing the infered mileage sensor which is also in that same general area. If the wiper switch won't urn to the left you do not have intermittent wipers. But if you want the go to Ebay...they're always on there cheap. Its the easiest upgrade you can do on these trucks.
I always wondered why i could turn my **** to the left. It never did anything. I got a new switch and it now goes the same speed as the slow setting while turning to the right.
It looks like I'm off the the junk yard again. Wish I had known last week, I was there and probably passed by a few.
When buying used parts, the governor for 1980/83 (E0TZ-17C476-A), won't work 1984/91 because the mounting plate is different.
The new replacing part fits all years, the original 1980/83 part will not.
turnkyle
12-31-2011 11:53 AM
