sirius - connection error - contact dealer
Old 06-28-2008, 02:53 PM
fordmanss12's Avatar
fordmanss12
fordmanss12 is offline
Went to drive away this am and listen to 132 (sirius) and in pressing the SR button on my factory NAV unit is immediately says "Connection Error - Contact Dealer"
Does anyone have any ideas?I thought maybe a fuse had gone for the sirius module but I can't find what fuse # is uses... the NAV unit acts as if the module isn't there (no info showing up under Sysinfo).
Thanks
Old 06-28-2008, 07:05 PM
rebelyell618's Avatar
rebelyell618
rebelyell618 is offline
not trying to be smart A but have you payed the sirius bill lately?
just making sure the basic troubleshooting is out of the way
Old 06-29-2008, 06:07 AM
fordmanss12
yup it is a lifetime subscription and I did check with sirius and there's no problem at their end. Also, when I go into sysinfo it should show the # of the sirius module, but it's blank.
Old 06-29-2008, 08:29 PM
rebelyell618
the only other option i can think of before ripping into the radio or fuses is to have sirius send a re-activation signal to your radio (shouldn't cost anything).
if that doesn't work then i would look at fuses (doubt that is the problem), and then from there on out it could be a connection problem with the antenna setup. last if none of those then there could be an equipment problem.
Old 10-07-2013, 11:16 PM
jmyers72ci's Avatar
jmyers72ci
jmyers72ci is offline
Connection error-Contact dealer Resolved
I had this exact problem and reset the entire radio and DVD system by removing the "radio" fuse while the system was powered on. It reset the entire unit including the Navigation system and Sirius no longer had error message, but DVD player did. I activated the DVD player from the rear console and the DVD player operated and the connection error was no longer there. Seemed to be an easy fix by simply resetting the system by removing and reinstalling the fuse.
ad5dg
1999 to 2016 Super Duty
03-12-2022 05:07 PM
Duwop
Ford In-Vehicle Tech
07-09-2016 09:34 AM
Criegg
10-26-2015 07:46 PM
achoo
01-08-2012 11:31 AM
Mudd460
2009 - 2014 F150
10-11-2010 06:27 PM
Quick Reply: sirius - connection error - contact dealer
