a guy at work is running this recipe
10 gallons used vegetableoil
1 gallon of Kerosene
½ gallon of regular gasoline
1.5 oz of STA-BIL fuel stabilizer
7 oz of Diesel Klean with cetane boost
a guy at work is running this in a benz. and has ran 2 tanks. anyone else try or are running this blend? what are your results or opinions? i told him i'll let him do the experimenting and see how it goes. He's running this thru his tank like normal diesel fuel. thanks for any input.[/FONT]
a guy at work is running this in a benz. and has ran 2 tanks. anyone else try or are running this blend? what are your results or opinions? i told him i'll let him do the experimenting and see how it goes. He's running this thru his tank like normal diesel fuel. thanks for any input.[/font]
He's running around 86% used veg oil, 9% kerosene, 4% gasoline and 1% addatives. Thats a pretty exotic blend he's come up with. Where'd he get those proportions?
funny, I was thinking the same thing. All he is missing is mothballs .
I am no expert. But i make bioD and round my measurements up in imperial. So far, my BD has passed wash tests and 3/27 tests without a problem.
Have him take some of that stuff and mix it 50/50 with water, in a bottle, and shake it up. then let it set for a while and see what it looks like .
Yeah, pretty much...
Kind of a crapshoot - varies from vehicle to vehicle. Some people have supposedly had pretty good short term success (at least according to the testimonials on their site) and others have had lousy experience with it.
The big problem is that they sell a bottle of thir secret ingredient "catalyst" - for an exorbident price - that is supposed to make the other ingredients stay mixed and transform them into a diesel equivalent. But it is really just a blend of common ingredients that, as far as anyone can figure out, doesn't really do much of anything - except put a big profit margin in their pocket. They also use the term biodiesel to refer to the end product of their blend - which is an outright lie.
[quote=CheaperJeeper;6288826]Yeah, pretty much...
CheaperJeeper does this formula do any damage the motor? Does anyone know where this formula originated from?
Another question is how was this "formula" arrived at? Again, we just don't know. It kinda seems like a "dash of this and a dash of that and a pinch of something else" approach to me. I've certainly never seen anyone give an explanation like "the kerosene is there to provide X component that is found in diesel, and the gasoline provides thinning and lowers the Y properties of the mix to make it more like regular diesel, and the Sta-Bil makes up for the fact that WVO is lacking the Z component of diesel...etc." So is there a valid scientific explanation like that? Who knows? Like I said - kind of a crapshoot.
I have put over 26,000 miles on a 93 Dodge Cummins running an oil mixture. Burned out one injection pump, but who knows if that would have done that anyway, since Injection pumps burn out running diesel. I have had luck in other vehicles to, including recently started burning it in Powerstrokes. My formula changes with the weather, but is basically 15-35 percent diesel or kerosene if I can get it. You can say a million things about it, but it WILL stay mixed and it WILL burn and I have had no serious issues. I have made biodiesel as well, but decided it was too dangerous and too much trouble.
Well, I've been doing some more research on blending and the most extensive testing seems to have been done by a German dude, Hans Peter Schur. Most of his testing was done with an old Mercedes IDI - just like what I want to burn the majority of my veg oil in (its my daily driver). If you Google Schur Ecofuel you can find more info about him - though a LOT of it is in German.
Anyway, his blend was 80% veg oil, 16% unleaded gas, and 4% isopropyl alcohol. In a 21 gallon tank that translates to 17 gallons veg oil, 3 gallons gas, and one gallon isopropyl. A little more research and I've found that pure isopropyl alcohol is WAY too expensive to make this work. Like $15-$25 a gallon expensive. The main function of the isopropyl is to counter the octane of the gasoline and raise the cetane value.
So, some more researching and reading and internet chatting with other blenders and the most common blend seems to be 80%-90% veg oil, 10%-20% unleaded gas, and some DieselKleen or other cetane improver to take the place of the isopropyl and raise the cetane. Another trick one guy shared with me is he uses stale gasoline he gets from wrecking yards for blending - because stale gas has a lot lower octane to begin with (most of the octane addatives have evaporated). He only mixes 10% gasoline with his veg oil and has run over 50k miles on this blend in two vehicles (37k in one of them) and has had NO unusual problems at all. And he lives in MARYLAND - which has a much more extreme climate than I have here in Washington.
So, until I get my fuel heating system completed, I'm going to try about 15% unleaded gas mixed with my SVO and some DieselKleen to boost the cetane. I already have somewhere in the neighborhood of 10 gallons of stale gas in my boat that I need to burn up anyway - and it has top quality 2 stroke oil already mixed in it at 50:1 ratio...
