Does this recipe sound right??
Old 06-24-2008, 10:33 AM
KyleG's Avatar
KyleG
KyleG is offline
Does this boidiesel recipe sound right to you guys??
30 Gallons of used oil
6.6 Gallons of methanol
567.9 grams of lye/or 20 ounces
---the oil is very, very clean and almost brand new in this batch...do those numbers look correct?
Old 06-24-2008, 10:57 AM
empiretc's Avatar
empiretc
empiretc is offline
What kind of lye? What did the oil titration show?
Old 06-24-2008, 11:20 AM
KyleG's Avatar
KyleG
KyleG is offline
i have Rooto Household 100% lye....and in my titration i ended up adding 2/5 of 1 ml of the lye/water solution, which i think would be .0004 g/L...right? then plugged these numers in the bio-diesel recipe calculator online, and i got 567.9 grams.
Old 06-24-2008, 11:49 AM
empiretc's Avatar
empiretc
empiretc is offline
Rooto is NaOH.
Your titration didn't take much. You could just use the base amount. Base for NaOH is 5g/liter. So for 30 gallons, you would need about 600g or 1.3 pounds.
I would use a little more methanol than that. Some use 20% and some use 25% so you're in the ballpark.
Old 06-24-2008, 11:51 AM
CheaperJeeper's Avatar
CheaperJeeper
CheaperJeeper is offline
I'm not familiar with that brand of lye, but my buddy just started making bio with brand new corn/soy oil blend (right out of the unopened containers) and is using sodium hydroxide NaOH, and according to his titration methods, the new oil required 580 grams lye for 25 gallons of oil.
Seems to me like you might be going a bit light on the lye...
Old 06-24-2008, 11:52 AM
KyleG's Avatar
KyleG
KyleG is offline
will do, thanks.
Old 06-24-2008, 11:57 AM
KyleG's Avatar
KyleG
KyleG is offline
how long do you guys usually let your batches sit after mixing?
Old 06-24-2008, 12:04 PM
empiretc's Avatar
empiretc
empiretc is offline
12-24 hours recommended.
I usually let it sit overnight and take care of it the next day.
Old 06-24-2008, 02:04 PM
KyleG's Avatar
KyleG
KyleG is offline
one more thing should i leave my heat going when i am mixing or just shut it off and let it cool slowly while mixing?
Old 06-24-2008, 02:25 PM
empiretc's Avatar
empiretc
empiretc is offline
You need to maintain 130 during processing.
Old 06-24-2008, 02:48 PM
KyleG's Avatar
KyleG
KyleG is offline
okay thanks
Old 06-24-2008, 06:39 PM
KyleG's Avatar
KyleG
KyleG is offline
wait do i have to keep it at 130 degrees even when i let it set over night??
Old 06-24-2008, 07:33 PM
empiretc's Avatar
empiretc
empiretc is offline
no, not when settling. just during processing.
Old 06-26-2008, 10:53 AM
KyleG's Avatar
KyleG
KyleG is offline
If I am not washing my fuel, should my base amount of lye be 3.5 g/L instead of 5. i plan on dry washing my fuel soon, but for now i am running unwashed in my old 86. so what do you think.
Old 06-26-2008, 12:42 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
5 gm/lt for NaOH
7 gm/ltr for KOH ( 100%)
7.8 gm/ltr for 90% KOH
And I would never run "raw" biodiesel.....................
Quick Reply: Does this recipe sound right??
