Dome Light Question
Dome Light Question
Dumb question here, noticed the other night that none of the dome lights are working. Is there a switch or something that could have gotten bumped etc.? I didn't find anything in the computer setup (07 Limited) to control it....it's not a big enough deal to go right to the dealer with but wanted to see if there is an easy fix before taking it over in the next few weeks.
Ah - the only dumb question is the one not asked.
One thing with the dome lights... they will not turn on if the dash light dimmer is turned all of the way down, similar to how they turn on if it is turned all of the way up. One way that I keep from burning the battery down when I leave the hatch open when working on a project around the house. This might be the culprit. If not, then it's down to starting to look at fuses, etc...
-Mike
2000 Mercury Mountaineer
2008 Ford Expedition EL XLT
2001 Keystone Bobcat 280BH
-Mike
-Mike
Thats true, I had a similar problem, do you have any accessories, like phone charger, GPS, car stereo...that was the culprit in mine, a week sitting without starting with accessories plugged in = dead battery. I had the same exact problem with my 06 Explorer. I put an optima deep cycle battery, a battery buddy and wired a new outlet strip off of a switched fuse in the fuse panel that is deenergized when the key is off, voila problem solved. (battery buddy disconnects the battery via solenoid when terminal volts drops below 12ish. When you touch the brake pedal, it reconnects the battery, therefore you can always start the truck)
Sorry to resurrect an old thread; I have a ‘14 XL. On this truck it seems the only way to turn on the dome lights is by opening the doors or rolling the dimmer switch. Each individual light can be turned off by pushing on the lens. It would be nice to turn on individual lights to read or look at something without having to turn them all on. Do the better equipped Expeditions (XLT, Limited) have that feature or is there a switch to activate that?
quitcrab
03-26-2017 05:13 AM
quitcrab
03-24-2017 06:01 PM
tvliftcabinet
02-26-2017 05:06 PM
mrstephs
04-16-2016 08:13 AM
84StraightSix
08-31-2014 12:35 PM
