Now Intake
Old 06-12-2008, 06:04 PM
threefiftyone's Avatar
threefiftyone
threefiftyone is offline
Now Intake
Which intake systems do ya'll have? Any home mades out there? Or, in this instance is the stock pretty good; so just get a drop-in? Thanks
Thanks Ford for making a great vehicle! Oh yeah - American. Too much negativity in this forum. Politically uncorrect and proud of it!
Old 06-12-2008, 06:22 PM
berry1234's Avatar
berry1234
berry1234 is offline
Stock. Had an Air Raid on my 05 F-150. Made little difference. I would rather just get a washable filter and be done with it.
Old 06-13-2008, 04:41 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
I agree, just get a drop in, the factory intake is almost a cold air intake anyway, not sure how you can make it much better short of maybe putting a hood scoop or something like that, forgot to mention, according to my scangage, the intake temperature is within 1 or 2 degrees of the outside temperature, certainly doesn't get better than that.
Old 06-15-2008, 02:36 AM
threefiftyone
what's a "scangage"?
Old 06-15-2008, 06:16 AM
chuck s's Avatar
chuck s
chuck s is offline
This is a scan gage. Not showing intake air temperature in the photo, but it will if you want. Since that temperature is displayed constantly on the instrument panel it's of little interest on the auxillary gage.
-- Chuck
Old 06-15-2008, 06:35 AM
nfntruth's Avatar
nfntruth
nfntruth is offline
Thats a big version of the one I have, but exactly right. My instrument cluster does not display intake temp? You must have an EB or Limited. The scangage displays just about everything the truck monitors, and it plugs into your OBDII port, plug n play just a bout every vehicle since 96, very easy and relatively inexpensive. Mine also reads any engine fault codes and gives me the ability to reset them. Just a gadget...
Old 06-16-2008, 10:53 AM
berry1234's Avatar
berry1234
Nice gadget!
Old 06-16-2008, 05:43 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
It generally stays in my car, for gas mileage tracking, but it is not vehicle specific and easily transfers from vehicle to vehicle. You can find them 100 to 150. It monitors fuel rail pressure, throttle position, %load on the engine, and a ton of other parameters in real time. Like I said, just a gadget...certainly not a necessity.
Old 06-23-2008, 01:18 PM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
I agree with the factory intake is basically a cold air intake. With my MSD Dashawk monitor, I'm seeing temps at cruising speeds <5°F then the outside temperature display on the dash.
I was a bit disappointed that it is so efficient because that means that an aftermarket KAI won't add any cooler air for improved efficiency.
Old 06-23-2008, 02:31 PM
berry1234's Avatar
berry1234
Shouldn't CAI be called AII. Ambient air intake? Cold air? I guess if we took a ice chest full of ice and routed the air intake through that, it would be a cold air intake.
Old 06-30-2008, 08:21 PM
hjsimpson's Avatar
hjsimpson
hjsimpson is offline
I was really hoping that Volant would have produced a CAI (w/ PowerCore Filter) for the 07 and up.
Volant Performance
No luck as of yet but if doesnt come soon I may just have to go with the K&N Version.
Anyone that has the K&N, how loud is it? Any increase in power or gass mileage?
Old 07-03-2008, 01:35 PM
nebmike's Avatar
nebmike
nebmike is offline
Most of the newer factory set-ups will draw air from 'outside' the vehicle -- which is to say, it wont be artificially hot air from inside the engine compartment. My Scangage indicates the same as nfntruth said, within a couple of degrees (usually) of the ambient air temp (unless you're at idle or moving slow while 4x4'n - then it'll jump up).
Even aftermarket CAI's will only give you air that is the same temp as ambient air. On a hot day, using the ice trick would probably just confuse the computer and cause you to run really rich and lose power and economy.
