New Process
New Process
Many of you know that I'll be building a new larger plant this winter. It will not be a "batch" process, but continious flow. The link below will explain some of the process that I'll be using. With the addition of improvements that I've been working on, we should be able to process 1,000 gallons/day. While running it will input new canola oil at one end, and finished bio at the other, with continious Methanol recovery and recycling. Plans are finished. Drawings done. Local permits in place. I have a wheat harvest to get through, and Fall planting to do before I can start, BUT I'M SO PUMPED!!!!
Ultrasonic Transesterification of Oil to Biodiesel
Already working on a smaller model for small processors
Their smallest model will do aprox 25 gal/hr at 1,000 watts. I think I can design a smaller system in the 4-500 watt range that would process about 10-12 gallons per hour.........................
Most of what is needed are off the shelf components!
10-12 Gallons an hour is about right.
Some day I am going to drive out to your ranch and buy you a beer for all the help you give on here.
fabmandelux
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-23-2006 10:18 AM
fabmandelux
11-18-2005 01:12 PM
