Vibration in '07 EL 4x4
Old 06-08-2008, 02:51 PM
nebmike's Avatar
nebmike
nebmike is offline
Recently, my Expy (18k miles) started to vibrate through the steering wheel once you get up to about 70mph -- with the vibration getting progressively worse as you increase speed past there.
Had the tires rotated and balanced but that doesnt seem to have done anything to correct the vibration. Its not the brakes - there is no vibration under braking (at least below 70mph).
Any thoughts on where I might look next?
Old 06-08-2008, 07:30 PM
Tmod700's Avatar
Tmod700
Tmod700 is offline
I would check the driveshafts.
Tmod
Old 06-09-2008, 10:50 AM
berry1234's Avatar
berry1234
berry1234 is offline
That's what I was thinking. Bent/out of balance driveshaft. Keep on the dealer.
Old 06-09-2008, 11:23 AM
nebmike's Avatar
nebmike
nebmike is offline
I'm 'bout to get sick of taking this thing back to the dealer for stuff. It hasnt been anything big yet, but dang, in the five months I've owned it I've had it in 9 times.
Old 06-09-2008, 05:49 PM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
to me it sounds like something else, something suspension related. I'd check out tie rods, inner and outer, idler arm, pitman arm, etc. Are you sure that the rotor is all the way back and the tire is mounted correctly? Jack the front wheel up and see if there is any play in it. I'd also make sure there isn't any mud on the inside of the rims or on the control arms. It also sounds like you need a service department not a parts changer.
Old 06-10-2008, 11:49 AM
Phity Five's Avatar
Phity Five
Phity Five is offline
I choosen to be patient with a vibration problem until I can understand it better or until someone else has a similar problem I can learn from or until FORD admits a problem and offers a service protocal.
Mine is mysterious in that it comes and goes with no clear rhyme or reason. It's mostly felt in the steering wheel, which will vibrate back and forth, usually between 50 mph and 70 mph, but will go away after between 1 and 3 miles of driving. It's not every day that it occurs, and the violence of the vibration is sometimes mild and sometimes quite alarming. It's not weather (temp or precip) related that I can tell, but it usually occurs in the morning or after long periods (4-5 hours) of being parked.
I've had the tires and rims checked and rotated (only 5500 miles on this `08 Expy), but no effect. Plus, if it were driveline related, wouldnt it be everpresent rather than come and go?
Have been to dealer twice, but of course they/I cannot reproduce the problem at that time.
My latest "clue" is that when I tow (24' Featherlite with 4500# load) the vibration, when/if it occurs, is more like a forced movement of the steering wheel rather than a vibration... not very clear in my description, I know, but its making me believe it is POWER STEERING related. Perhaps the spooling is fouled, or some valve is sticking, or ? But this dampening effect under tow load, along with the notion that maybe system/fluid temperature may have something to do with it, I'm thinking the steering pump is the culpret.
Any concurance here on my suspicions? Any other thoughts on what it might be?
Thanks... Brian
Old 06-10-2008, 12:07 PM
berry1234's Avatar
berry1234
I would video the wheel shaking. Send ford a certified letter about your complaint. After 3 attempts, go through whatever your states steps are for filing a lemon. Easy to file. When Ford gets that paper work, they usually respond.
battmanf16
22
03-11-2020 11:36 PM
mjs
1999 to 2016 Super Duty
25
06-21-2005 09:46 AM
mowreyp
2004 - 2008 F150
04-17-2005 04:02 AM
Triboy
03-14-2005 08:03 PM
khendrix
2004 - 2008 F150
11-02-2004 06:59 PM
Quick Reply: Vibration in '07 EL 4x4
