List of mileage boosters
This has been discussed over and over but I haven't seen a comprehensive list developed. Can we TRY that here - each poster simply copy the latest poster's list and add their own points. (Leave discussions to other threads and just stick to point form itemization. Embellish or create improved comments rather than trash a prior person's item - whether it's rightly or wrongly in the list at all.)
Maybe don't worry about order - it's highly debatable as are my categories
Generally Easy and Cheap
- improve driving style
- remove roof rack crossmembers
- higher tire pressures
- use a winter front in the winter (air dam effect and impoved engine temp.)
- carry less weight
Less than roughly $500
- engine tune up
- after market air filter
- after market exhaust
- diesel chip
Over $500
- change to highway vs offroad tires (reduced rolling resistance)
- remove push bars, etc.
Involves work, testing and uncertain costs and results
- improved aerodynamics
- - air dam
- - underbelly smoothing
- - rear deflectors
- hydrogen generators :-) (just kidding)
- carry less weight
- engine tune up
- diesel chip
Over $500
- - air dam
- - rear deflectors
- Scan Gauge II (or similar) to monitor Load, Throttle Position, manifold pressure etc. to help improve MPG driving style.
- carry less weight
- keep your engine clean
- proper weight oil
- verify proper tire alignment
- engine tune up
- diesel chip
Over $500
- - air dam
- - rear deflectors
- Flux capacitor serious...
- carry less weight
- proper weight oil
- engine tune up
- diesel chip
Over $500
- - air dam
- - rear deflectors
That doesn't work as well as the Bussard Collectors.
A highly fictionalized variation of this concept, called the Bussard Hydrogen Collector or Bussard Ramscoop appears in the Star Trek saga as part of the matter/antimatter propulsion system that allows Starfleet ships to travel faster than the speed of light. In the saga, the ramscoops attach to the front of the warp nacelles, where (when the ship's internal supply of deuterium runs critically low) they collect interstellar hydrogen and convert it to deuterium and anti-deuterium for use as the primary fuel in a starship's warp drive.
Don't buy from them. I bought the engine oil bypass kit to help reduce pumping losses and found that my mileage went UP. I'd like to get the dual o-pipe but won't buy from them. I'll wait until somebody else carries one.
Oh boy...
Oh boy...
- Vacuum gauge (cheaper?)
- carry less weight
- proper weight oil
- engine tune up
- diesel chip
Over $500
- - air dam
- - rear deflectors
- - trim windshield w/electrical tape smooths airflow, cuts noise and fixes leakes too :-)
- - Vortex Generators (air tabs)
Note: sounds like Vortex Generators beat Hydrogen Generators.
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
url=http://www.autospeed.com/cms/A_3061/article.html
- carry less weight
- proper weight oil
- engine tune up
- diesel chip
Over $500
- - air dam
- - rear deflectors
Exactly! That's what I did 2 weeks ago! Drving a 25mpg vehicle now and it's nice saving $$$$ I will only drive the Ex for towing, the rest of the time it's parked in the garage!
Yes - I guess walking works too. I've added it below..
- walk or take a bus or borrow someone else's car, take a balloon (or whatever involves just not driving the EX which has the benefit of reducing its depreciation)...
- carry less weight
- drive something else (if you have it)
- engine tune up
- diesel chip
Over $500
- Buy something else (if you have to)
- - air dam
- - rear deflectors
- carry less weight
- engine tune up
- diesel chip
Over $500
- - air dam
- - rear deflectors
