Vegistroke Excursion Prototype Finally Done
Old 05-29-2008, 09:10 PM
FN74's Avatar
FN74
FN74 is offline
Well guys, here it is. Here are some pictures of our new 40 gallon auxillary Excursion Tank. There are still a few refinements and adjustoments that need to be made, but this is basically it. This is an all aluminum heated auxillary tank that is comletely independent of the OEM tank. There is a 30 gn low profile tank as well that will be 3" more shallow. We are particularly porud of our filler door solution. Sound off and let us know what you think!!
Old 05-29-2008, 09:12 PM
FN74's Avatar
FN74
FN74 is offline
Filler Door
Old 05-29-2008, 09:14 PM
FN74's Avatar
FN74
FN74 is offline
One view of the filler door.
Old 05-29-2008, 09:15 PM
FN74's Avatar
FN74
FN74 is offline
Filler door open
Old 05-29-2008, 09:17 PM
FN74's Avatar
FN74
FN74 is offline
Tank from beneath
Old 05-30-2008, 03:30 AM
Super Steve's Avatar
Super Steve
Super Steve is offline
Looks good.
Is that gas filler cap from a motorcycle?
It looks awfully familiar.
Old 05-30-2008, 04:21 AM
zhilton's Avatar
zhilton
zhilton is offline
I admire the engineering work ya'll did on that truck. Though I don't foresee buying an Excursion since we have the F250...but my wife could always upgrade from the Explorer to an Excursion; I'll keep this kit in mind. Really nice looking work there guys.
Old 05-30-2008, 05:31 AM
FastCote's Avatar
FastCote
FastCote is offline
Sweet!
Will that tank/filler concept work on a 2005 350? Will you be offering it as an option to the V3 turnkey system?
Eagerly awaiting your call so i can get going on a purchase.
Old 05-30-2008, 03:11 PM
indebt's Avatar
indebt
indebt is offline
how about a strap on that new tank, or are the mounting tabs strong enough? considering weight. Looks good love the filler solution
Old 05-30-2008, 04:30 PM
FN74's Avatar
FN74
FN74 is offline
Yep, the mounting tabs are plenty strong enough. Oil is ~7.6lbs/gn times 40 gallons equals 304lbs, divided by 4 tabs is only 75lbs per tab. Each tab has been tested to support over 250lbs without defection. So really the tank should be able to easily support 1,000 lbs. The only thing that I will likely do given how far down that tank sits is weld a double layer on the bottom.
And on the filler door, you can lock it too with the door locks so no one can steal our valuable oil...
Old 05-30-2008, 05:31 PM
zhilton's Avatar
zhilton
zhilton is offline
I didn't even think about that simple little detail about the VO filler door. Like I said...really nice looking engineering work there guys.
Old 06-03-2008, 12:08 AM
mps1ualberta's Avatar
mps1ualberta
mps1ualberta is offline
Looks really good guys, the gas filler cap is really nice.
Old 06-03-2008, 09:43 AM
Upcamper's Avatar
Upcamper
Upcamper is offline
very nice set up, one of the best I've seen so-far!!
Old 06-03-2008, 01:42 PM
GeoDad's Avatar
GeoDad
GeoDad is offline
Very nice! I'm ready to order one. When will they be available?
thanks,
-gary
Old 06-04-2008, 06:23 PM
fiveohpatrol's Avatar
fiveohpatrol
fiveohpatrol is offline
absolutely brilliant! I can't wait to get mine!
-Drew
Quick Reply: Vegistroke Excursion Prototype Finally Done
