Mileage?
Mileage?
I got my truck back with a new trans so we went to Va. for the weekend and my mileage was worse than ever! 8/9 MPG on the way down. On the trip home it was better 14.7 MPG but not what I was getting. So today I removed the EGR valve and cleaned it. It was a mess. I put it back and everything was ok. I don't know if it will help with the mileage but at this point anything may help. I called the dealer and he told me there is nothing that they can do if there are no codes showing. I asked if it needed to be reprogrammed. He told me it will not help that is the best that I can get. I am not to impressed. I wish the trans never went bad.
All of the guages you listed are a waste on a stock truck....except for general knowledge purposes. The PCM will govern all those settings on the 6.0 and power down before they get too high.
I'm not too sure of the idea of the break-in period being involved with the mileage. Just speaking from experience,once the trans is replaced,usually there is a recalibration to go with it. Most likely if this happened,the learning strategy was erased and slowly the dummy-guage will read closer to the actual mileage.
I hope before you reinstalled the egr valve into the intake that you replaced the o-rings and gasket. Most times when removed the old ones get burrs or damage and will cause a leak,decreasing flow,back-pressure,etc,etc,etc The kit is only like ten bucks at the dealer.
See maybe I assumed too much and figured the shop/dealer would have done the recalibration so that is why I figured it might be a break in thing. Guages, well i guess it more of a personal thing. I like to see a needle point to a number or see it digitally. Just me though. I can gain a better knowlage of how my truck runs and opperates better then with a swing guage with green and red areas. Saved a couple fire trucks I drove because I noticed a pattern by watching the guages we had, they were numbered not general ok/bad type.
Not disagreeing with that Ryan. I for one would install guages in a diesel truck if I owned one. Most people that get them are doing it cause they look cool or just to say that they know what's going on with their truck. Most of those wouldn't understand what that boost or egt measurements are telling them about their motor,except that the boost is high/low and the egts are high/low. Edge(not to knock their products)enable owners to change fuel trim and all other sorts of stuff that if done improperly could do some serious damage. The other guys using SCT and other premade/preset programmers are driving their trucks with calibrations that the company sets up for them....not to the individual. Bad move in my opinion.
