1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2003 F250 headlight assembly removal
Old 05-24-2008, 10:26 PM
BigTrucK72's Avatar
BigTrucK72
BigTrucK72 is offline
I recently purchased some clear corners and finally got around to installing them this memorial day weekend. When I read the manual it said there were some metal clips to remove the headlight assembly.
So I found the clips and was able to easly remove the clip on the passenger side assembly closest to the tire with no prob. But the other metal clip toward the radiator is a little more difficult b/c it's almost a vertical leverage. I feel like that if I put any more force on the tab that I am going to break it. Anyone have any suggestions?
Thanks.
Old 05-25-2008, 02:43 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
You won't break the clip, just keep fighting it with a pair of needle nose and a standard screwdriver and it will eventually oblige. Some four letter words helped when I did it. Wiggle it side to side and try to 'walk' it up off the plastic stud. Good luck!
BuckHammer
03-12-2016 09:44 PM
houlis
09-02-2012 09:50 PM
cdnalpina
03-01-2010 08:49 AM
KevVer
01-24-2010 03:43 PM
ronnie95252
1983 - 2012 Ranger & B-Series
12-12-2006 09:04 PM
Quick Reply: 2003 F250 headlight assembly removal
