Oil Leak?
Old 03-24-2002, 10:28 PM
thelonerangerxlt's Avatar
thelonerangerxlt
thelonerangerxlt is offline
Oil Leak?
I have a 2.3L in a 92 Mustang. Lately it's been dripping a little oil on the garage floor. I changed the oil last weekend, and narrowed the possible leak sources down to either the valve cover gasket, or a rear main seal. (I'm hoping for the valve cover gasket) My question is: how many miles should a rear main seal last? The engine has about 117K miles on it.
Old 03-25-2002, 10:34 AM
tomw's Avatar
tomw
tomw is offline
Post Oil Leak?
The rear main should last a LONG time. The cam cover probably will leak 2 to 3 times before the rear main. Also, you should check the block/head sealing as I had oil coming down the side of the block from where the head rested on the block. I retorqued the head bolts with the engine cold, and the oil leak stopped...
tom
Old 03-26-2002, 09:41 PM
thelonerangerxlt
Oil Leak?
Thanks, Tom. That's what I wanted to hear. I will try re-torqueing the cam cover bolts this weekend, and change it out when the weather warms up.
Old 04-29-2002, 04:41 AM
Drizzt's Avatar
Drizzt
Drizzt is offline
Oil Leak?
are you sure it's leaking oil and not tranny or p/s fluid? could be a bad pitman seal
Old 05-01-2002, 06:30 AM
Badfunkn's Avatar
Badfunkn
Badfunkn is offline
Oil Leak?
Mean66
06-11-2012 12:19 AM
mrblonde108
11-10-2011 08:11 AM
FordF350Baby
05-19-2009 08:05 PM
86OldBlue
04-03-2007 09:26 PM
novicebob
11-01-2002 05:22 AM
Quick Reply: Oil Leak?
