1950 flathead v8 wide vs. narrow pully engines?
Old 05-12-2002, 07:04 AM
Kurts50's Avatar
Kurts50
Kurts50 is offline
I just purchased a 1950 flathead v8. I had 2 to chose from (not sure of the other year but my f5 dually is a 1950). I picked the 1950 engine as my engine has a cracked block. I paid $300 for it and supposely it runs good. He advertised the two engines as one having "narrow" pulleys and one having "wide" pulleys. The one I picked has the narrow pulleys. What's the difference? If my f5 has wide pulleys will everything interchange onto the new engine? Thanks!
Old 05-12-2002, 05:23 PM
mtflat's Avatar
mtflat
mtflat is online now
Trucks ran the wide belt pulley while the narrow belts were found on cars. The engines are identical for all practical purposes, and with the 50 engine you should have hardened valve seats which is a plus. If you bought the engine complete (including fan, generator, etc.), you can run it as is. If all those goodies are absent, you could swap the bolt on belt accessories from your cracked engine since all flathead blocks are the same (48-53 US trucks).
Check to see if the fan lines up with your radiator shroud. As long as the engine runs with no cracks or other problems, I'd say you did good. - tim
Old 05-20-2002, 05:01 PM
mantta's Avatar
mantta
mantta is offline
I had a 49 Ford car with a V-8 and it had wide pulleys. I noticed at that time that the 50s and up had the narrow pulleys on them.
Old 05-22-2002, 03:17 PM
hamz52's Avatar
hamz52
hamz52 is offline
Hi
You might also want to check the distance between mounting
holes on the narrow belt water pumps. I tried to drop in a
motor with them once in my 52 and they didn't match up with stock
motor mounts. Barely missed so I had to change out the water
pumps to the wide belt for the truck. Good luck
Hamilton
Old 06-10-2002, 08:13 PM
MikeInNM's Avatar
MikeInNM
MikeInNM is offline
gary's1950F1
11-21-2016 11:11 PM
farmall_7
05-31-2016 08:14 PM
farmall_7
05-18-2016 12:52 PM
Poes
18
06-06-2015 01:55 PM
10strokin
15
04-18-2006 05:10 PM
Quick Reply: 1950 flathead v8 wide vs. narrow pully engines?
