rpm
Old 11-02-2002, 05:29 PM
41Clay's Avatar
41Clay
41Clay is offline
rpm
Isn't the normal max rpm of the flathead around 3600? Is there a way I can increase that to around 6000? What is holding the flathead back, is it just the breathing? It may sound crazy but I will appreciate any opinions/facts on this.
Old 11-04-2002, 07:37 AM
chukm's Avatar
chukm
chukm is offline
rpm
That is most likely the rpm @ peak HP not redline.
Old 11-04-2002, 04:42 PM
41Clay's Avatar
41Clay
41Clay is offline
rpm
[updated:LAST EDITED ON 04-Nov-02 AT 05:51 PM (EST)]Ok, so is it around 4200rpm? I'm thinking about replacing an engine that sees 4000rpm regularly and maxes at 70000rpm.
I'm looking at an 8BA 239 block. I would put on a girdle for the main caps, of course the full flow oiling, keep the compression about the same for the higher spinning, and an electronic ignition. Probribly go with a 390cmf quad, or adapt a holley 2300.
Old 11-04-2002, 07:22 PM
tcw's Avatar
tcw
tcw is offline
rpm
kens65fb
06-17-2017 12:09 AM
7FC-Driver
Flathead V8 & Flathead 6
11-20-2012 11:04 AM
whitley
10-23-2012 04:57 AM
Rj Williamson
03-17-2012 08:38 PM
1951flatheaddave
17
10-05-2011 11:49 AM
Quick Reply: rpm
