what bellhousing does the 239 have?
Old 11-02-2002, 11:22 AM
fordguy76's Avatar
fordguy76
fordguy76 is offline
i did a search and couldn't find anything. i know this has probably been asked many times too. does it have the same as a y-block or a 302 or what. or are they all different?
Old 12-01-2002, 08:48 PM
mtflat's Avatar
mtflat
mtflat is offline
Seth, sorry we missed your question. There were two 239 engines produced by Ford. Since you're in the flathead section, the 239 flathead produced from 1939 in the Mercury's until 1954 in Canada. The early ones (39-47 trucks) had the bellhousing cast on the rear of the block. Later ones (48 - 53, 54 Canada) had a separate bell housing that bolted to the block.
Then Ford produced a 239 OHV "Y" block engine in 1954 trucks. I'm not familiar with these, so you should probably ask over on the Y-block forum if that's what you're looking for.
In general the flathead bellhousing won't fit anything else, but several suppliers make adapters for fitting later standard and automatic trannies to flatheads.
Old 12-12-2002, 04:21 PM
fordguy76's Avatar
fordguy76
thanks for the reply. i was wanting to know about the flathead. i figured they had a unique bellhousing, but i wasn't sure
Old 12-18-2002, 12:21 PM
54_5star's Avatar
54_5star
54_5star is offline
spr1516
1999 to 2016 Super Duty
15
10-09-2008 08:30 AM
idifamilycab
08-19-2007 07:02 PM
tttario
06-20-2007 01:28 PM
nc150
02-08-2006 01:08 PM
christop43
1978 - 1996 Big Bronco
08-24-2002 11:09 PM
Quick Reply: what bellhousing does the 239 have?
