WVO issues
Old 05-11-2008, 11:54 PM
sa1765's Avatar
sa1765
sa1765 is offline
WVO issues
i'm asking this for my neighbor, so hopefully i don't miss anything. he's running a dual tank wvo setup and the truck performs fine under most all conditions...with 1 exception...under heavy load. he said it acts like it doesn't get enough fuel (wvo). he said the fuel line is heated, but the tank doesn't have a heating element....so i said that may be the problem, oil is still a little thicker than the diesel to flow properly...but that's just my guess. his wvo tank is a 100 gallon bed tank (what farmers use for tractor fuel). does anyone know if there is an electric element that can be used in those tanks? does anyone know if that is, or could be, the problem? does anyone have any other suggestions?
his is an '02 7.3 auto.
thanks
Old 05-12-2008, 12:41 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
thanks
Even when heated VO will be a lot thicker than diesel.
Old 05-12-2008, 03:13 PM
ALEXVB22's Avatar
ALEXVB22
ALEXVB22 is offline
You should check out www.Artic-fox.com they'll have everything you need for heating.
Alex
Old 05-13-2008, 07:47 PM
willbd's Avatar
willbd
willbd is offline
Do you know if he has a fuel filter just for the wvo? If he does it could be a pluged fuel filter.
Old 05-14-2008, 12:17 AM
sa1765's Avatar
sa1765
sa1765 is offline
i checked the artic-fox site...it was all rv related...was there something specific i should be looking for there?
yes, he does have a dedicated fuel filter for the wvo....i'll mention that to him. thanks
Old 05-14-2008, 08:07 AM
willbd's Avatar
willbd
willbd is offline
Old 05-14-2008, 11:48 AM
ALEXVB22's Avatar
ALEXVB22
ALEXVB22 is offline
Rv Related? I did'nt even see anything that had to do with RV specifically... I just clicked the link above that was posted and in the 3rd column over to the right scroll down and look for the B1-B100 heating information. That what I figured would be best for your heating application. I have no doubt that they could offer you very educated opinion on your Buddy's SVO/ WVO system... Call em' up...
Alex
Old 05-14-2008, 11:28 PM
willbd's Avatar
willbd
willbd is offline
I could see how there could be some confusion with the RV company that makes and sales a brand called Arctic Fox that is based in Oregon and a company that makes fuel heater products named Arctic Fox that’s out of Minnesota.
Old 05-16-2008, 12:05 AM
sa1765's Avatar
sa1765
sa1765 is offline
ok, found it....big (actually little) difference in websites...artic-fox is rv stuff...arctic-fox is what i needed.
once he checks/changes the fuel filter...if it doesn't do any good, i'll have him move on to the heater.
or...he'll just say "f&$k it"...i'll just burn diesel when pulling the stock trailer.
either way, i'll pass on the info.
thanks again.
Old 05-18-2008, 10:30 PM
TchTchr's Avatar
TchTchr
TchTchr is offline
Agree on check the fuel filter and heating the tank. The fuel pump may not be in the best shape too. I have a FASS on the vegistroke and it has PLENTY of oomph.
Swizzferd8
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-26-2014 08:43 AM
lio45
08-03-2012 03:52 PM
tylerp
1999 to 2016 Super Duty
18
10-05-2008 05:06 PM
dzzavid
03-06-2008 08:04 AM
myjack
03-14-2005 06:07 PM
Quick Reply: WVO issues
