5.8 oil cooler/radiator hose
Old 06-10-2000, 03:17 PM
ppoel's Avatar
ppoel
ppoel is offline
Anybody have an idea where I can obtain the correct lower radiator hose for my 1995 Bronco, 5.8L, Auto, with trailer tow package? There is a tee in the main hose with a feed and return that goes to a factory oil cooler attached to the block at the oil filter base. Non or the parts shops have the CORRECT hose for this application. I know the cooler is OE because I ordered and took delivery of the truck new. Thanks!
Old 06-12-2000, 10:17 PM
Katt's Avatar
Katt
Katt is offline
If you can't find it at a parts store, you can always get it from your local Ford Dealer. It'l cost more, but ya gotta get what ya gotta get.
Good Luck
Old 06-13-2000, 05:32 PM
ppoel's Avatar
ppoel
ppoel is offline
Yup I found out the only place to get it in my area id the dealer. Sure wisg it came with a jar of vasoline. Turned out to be $99 out the door!
Old 06-20-2000, 07:14 PM
78F100's Avatar
78F100
78F100 is offline
Can you get a new standard hose, cut it and attach each piece to the tee fitting? Or is the tee molded rubber? Maybe you can use a copper tee from the hardware, with short pieces of pipe sweated in to attach the hoses to.
Old 08-06-2000, 09:35 PM
78F100's Avatar
78F100
78F100 is offline
This may be a long shot. But, back in '72,'73 I remember seeing new 429 police intercepters coming down the assembly line with a oil to water heat exchanger similar to what you describe. The parts may be available from the auto parts stores for these. These were 1972 & 1973 Ford Galaxies or Customs (I don't remember which). I do remember that they were fast compared to standard LTD's. One other unrelated thing, they had hydraulic brake boosters (hooked up to the power steering pump, no vacuum booster).
Old 08-07-2000, 08:21 AM
gypsybill's Avatar
gypsybill
gypsybill is offline
GreenMM
33
09-03-2020 08:45 PM
WYOF150
10-07-2019 10:53 AM
kyleag89
06-26-2017 08:21 AM
Frijole
23
05-24-2016 10:11 PM
tchad07
1978 - 1996 Big Bronco
02-06-2007 06:22 AM
Quick Reply: 5.8 oil cooler/radiator hose
