Replacing oil pump in 302
Old 09-08-2001, 05:53 PM
block0's Avatar
block0
block0 is offline
I have a 1987 302 EFI engine in a Bronco (same year) that recently lost oil pressure. It had been taking longer and longer to come up to pressure lately (the past few months), and finally I went out to start it and had no pressure. So, I need to replace the pump. My Haynes manual says I have to remove the upper intake manifold and take out the radiator to raise the engine up a bit, but I can't see why either of these need to come off? Also, does anybody have any other advice for pulling the oil pan? Thanks.
Old 09-09-2001, 03:18 PM
david_mirabile's Avatar
david_mirabile
david_mirabile is offline
if you have a fan shroud remove it. then take the bolts loose from your motor mounts. then use a jack and a timber and gently jack the front of the motor using the harmonic balancer as the jacking point. i don't see why you would have to pull the intake.
Old 09-10-2001, 11:20 AM
loudfords's Avatar
loudfords
loudfords is offline
busby
Southern Region
12-30-2020 05:12 PM
51 F3 owner
08-06-2014 02:40 PM
ryder1541
19
08-24-2013 10:09 AM
garsm
07-31-2011 04:21 PM
SoNic67
23
11-17-2010 03:51 PM
Quick Reply: Replacing oil pump in 302
