Road Draft Tube
Old 04-28-2008, 12:33 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
Road Draft Tube
Do you have to have one? PVC valve?
I am going to have a flathead rebuilt for my truck and the engine currently doesn't have one (its missing). any specific info concerning draft tubes or alternates would be greatly appreciated.
Thanks
Josh
Old 04-28-2008, 02:54 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
The benefits of the PCV:
Positive, works all the time, not just when you are moving over a certain speed.
No frothy mess dripping on your driveway.
No oily haze around the breather.
You don't have to have one, but the draft tube is designed to pull fumes out of the motor. So, if you don't have one, you have some additional risk of internal sludge/goo buildup, or, wherever he tube attached, a mess there.
Old 04-29-2008, 03:39 AM
55 f350's Avatar
55 f350
55 f350 is offline
ross { albuq} had a list of parts ya need to put a pcv in . i got it somewhere but like so many other things it's been on hold for a freakin' coons age now .................. the pcv would be much better , although the people walking up to me telling me my truck has a bad exhaust leek and it's smoking is kinda funny ................
Old 04-29-2008, 10:53 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
thanks for the info,
I just got a price quote for the rebuild and machine work, Ouch!
Old 04-30-2008, 08:46 AM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Alright I'll bite, how do you put a PCV in when there are no valve covers, and no overhead vlaves for that matter?
Old 04-30-2008, 05:32 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
this from my question also posted on the MSN Flathead forum
Ford Flathead 1932 to 1953
Josh
Old 05-01-2008, 08:21 PM
effie_man's Avatar
effie_man
effie_man is offline
i plan on reworking mine so it goes back into my motor and burns up and eliminate it al together without a pcv
Old 05-01-2008, 09:52 PM
seven up's Avatar
seven up
seven up is offline
I ran a hose from the draft tube to an original ford carb spacer with the pcv attachment. And an inline pcv check valve. It needed a step down barb fitting. It's on a '60 OHV.
Cheers
Old 05-01-2008, 09:57 PM
effie_man's Avatar
effie_man
i plan on running a tube through under my intake and through the spare vent in the fuel pump to one of my carbs and burn off the gasses through the motor again
Old 05-01-2008, 11:47 PM
85e150's Avatar
85e150
You need the PCV valve to regulate this and prevent sucking oil directly in, and not have the connection just be a big vacuum leak. Look at pcv set ups and duplicate one.
Old 05-02-2008, 10:20 AM
effie_man's Avatar
effie_man
my flatty parts distributor does it to al his motors that he builds and he nevers has any problems. Hes a reputable guys who has been cited as a source for various hot rod magazine articles
Old 05-14-2008, 01:57 PM
rcav8or's Avatar
rcav8or
rcav8or is offline
If you use it, SUPPORT IT
Josh - you've kept us in suspense long enough!!! What was the quote? I'm curious, because I've debated building my "spare" block, just to have a spare...
R
Old 05-14-2008, 03:23 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
About $3600 which includes new timing gear upgraded cam, valves, align hone (which may not be neccesary),hardened valve inserts, can't rmember everything else but that was pretty much a worst case scenario, so hopefully it would actually end up being a lot less than that, all done and said. oh and it didn't include reassembly (just the valve assembly) I am still going to get a second quote for the same options and see how they compare.
I just need to remove the valves and cam at this point then I will get it in and magnafluxed to make sure its rebuildable. then it may sit a while until I find some $
Old 05-14-2008, 09:10 PM
rcav8or's Avatar
rcav8or
rcav8or is offline
Wow, that IS a lot...more than I figured, when I found out my block is probably good. You have gone a little further than I would have, but, when I got there, I know I would have gone ahead, and done it right...guess my $1200 rebuilt motor IS a good deal!!
Thanks,
R
Barney58F100
10-17-2015 10:13 AM
Marauder2004
01-27-2015 10:19 PM
Cougar54
18
05-12-2014 10:14 AM
Blitzcraig
02-08-2012 11:18 PM
Crewcab Turbo
01-06-2012 02:47 PM
Quick Reply: Road Draft Tube
