Camshaft casting numbers?
Old 04-22-2008, 07:50 PM
hotrodlincoln69's Avatar
hotrodlincoln69
hotrodlincoln69 is offline
I have two engines that I would like to know which camshafts they have. Are there casting numbers on the cams that I can interchange? The first engine is a 302 out of a 84 Mustang and I would like to double check if it has the HO cam. The other is a 351w from a 82 F150 and I am wondering if it has the 2v or 4v cam.
Old 04-22-2008, 09:22 PM
Conanski's Avatar
Conanski
Conanski is offline
No casting numbers that will decode to anything usefull I don't think. Get a dial indicator and measure lobe lift or valve lift with the cam in the motor, that alone will tell you what cams you have.. assuming they are stock.
Old 04-22-2008, 11:44 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Some of the later roller versions had letters stamped near the distributor drive (ZL and ZE), not sure about the earlier version though.
Old 04-23-2008, 04:12 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
There are no casting numbers on camshafts, and casting numbers cannot be cross referenced to part numbers.
Some cams have markings on them.
D5OZ-6250-A .. Camshaft ~ 1981/84 Mustang 255/302 exc. H.O. / Marked: DG or DH with reverse D
D3OZ-6250-A .. Camshaft ~ 1982/84 Mustang H.O. / Not marked / This same cam was used on 1973/75 351W's installed in passenger cars.
D6OZ-6250-C .. Camshaft ~ 1981/85 F150/350 351W 2V / Not marked.
No 351W 4V's till 1984.
Old 04-23-2008, 06:48 AM
hotrodlincoln69
Thanks for the help. I pulled the cam from the 302 and it has a HD (DH depending which way I look at it) so from the info it has the ****ty cam. There is also #27 on it.
The 351 isn't the original engine in the truck. It has a rebuild date on it and was bored .040 over. It also doesn't have the original intake.
Jakebanshee
1999 to 2016 Super Duty
06-17-2017 04:04 PM
RustyRatRod
Ford Truck Parts for Sale
05-06-2016 01:20 AM
Buckeye Rich
06-10-2010 02:14 PM
armynavyguy
Modular V8 (4.6L, 5.4L)
07-08-2007 04:01 AM
Torque1st
Oil & Lubrication
36
12-17-2005 11:12 AM
Quick Reply: Camshaft casting numbers?
